RTEMS 5.2
ALT_STATUS_CODE alt_qspi_erase_subsector (const uint32_t addr)
ALT_STATUS_CODE alt_qspi_erase_sector (const uint32_t addr)
ALT_STATUS_CODE alt_qspi_erase_chip (void)
The functions in this group are used to erase selected portions of a flash device.
◆ alt_qspi_erase_chip()
ALT_STATUS_CODE alt_qspi_erase_chip ( void  )
This function erases the entire flash device.
Return values
ALT_E_SUCCESSIndicates successful completion.
ALT_E_ERRORIndicates an error occurred.
◆ alt_qspi_erase_sector()
ALT_STATUS_CODE alt_qspi_erase_sector ( const uint32_t  addr)
This function erases the designated flash device sector.
This function erases the flash device sector containing the designated flash address. Any address within the sector is valid.
Parameters
addrA flash address contained within the the sector to be erased.
Return values
◆ alt_qspi_erase_subsector()
ALT_STATUS_CODE alt_qspi_erase_subsector ( const uint32_t  addr)
This function erases the designated flash device subsector.
This function erases the flash device subsector containing the designated flash address. Any address within the subsector is valid.
Parameters
addrA flash address contained within the the subsector to be erased.
Return values
