RTEMS 5.2
- l -
- l : tte_data
- l0 : SPARC_Minimum_stack_frame
- l0_and_l1 : Context_Control
- l1 : SPARC_Minimum_stack_frame
- l2 : Context_Control, SPARC_Minimum_stack_frame
- l3 : Context_Control, SPARC_Minimum_stack_frame
- l4 : Context_Control, SPARC_Minimum_stack_frame
- l5 : Context_Control, SPARC_Minimum_stack_frame
- l6 : Context_Control, SPARC_Minimum_stack_frame
- l7 : Context_Control, SPARC_Minimum_stack_frame
- l_next : link_map
- label : rtems_rtl_archive_symbol, rtems_rtl_loader_format
- LAR : DWT_Type, ITM_Type
- largest : Heap_Information
- last_cleanup_context : _Thread_Control
- last_close : rtems_termios_device_handler, sc16is752_context
- last_data_block : _rtems_rfs_inode, rtems_rfs_block_map_s
- last_errno : rtems_rap_data_s, rtems_rtl_data
- last_error : rtems_rap_data_s, rtems_rtl_data
- last_map_block : _rtems_rfs_inode, rtems_rfs_block_map_s
- last_target : ALT_I2C_DEV_s
- last_user_extensions_iterator : _Thread_Control
- latest_deadline : Rate_monotonic_Control
- lcd_fb_addr : _isi_Video
- lcd_hsize : _isi_Video
- lcd_nbpp : _isi_Video
- lcd_vsize : _isi_Video
- lcr : sc16is752_context
- left : rtems_bdbuf_buffer::rtems_bdbuf_avl_node
- legacy_device_context : rtems_termios_tty
- len : _GmacTxDescriptor::_GmacTxStatus::_GmacTxStatusBM, i2c_msg, mmap_mappings_s, spi_ioc_transfer, stm32f4_i2c_message
- length : bfin_uart_channel_t, Dual_ported_memory_Control, MP_packet_Prefix, Partition_Control, rtems_blkdev_sg_buffer, rtems_rtl_rap, rtems_rtl_unresolv_symbol, rtl_unresolved_name_data
- level : drvmgr_bus, drvmgr_dev, rtems_debugger_block, rtems_rtl_obj_cache, rtems_rtl_obj_cpmp
- libc_reent : _Thread_Control
- Life : _Thread_Control
- lifetime_allocated : Heap_Statistics
- lifetime_freed : Heap_Statistics
- LinBlueFieldPosition : RTEMS_PACKED
- LinBlueMaskSize : RTEMS_PACKED
- LinBytesPerScanLine : RTEMS_PACKED
- LinGreenFieldPosition : RTEMS_PACKED
- LinGreenMaskSize : RTEMS_PACKED
- link : _rtems_rfs_file_shared, _rtems_rfs_inode_handle, rtems_bdbuf_buffer, rtems_bdbuf_group, rtems_bdbuf_swapout_worker, rtems_rtl_obj, rtems_rtl_obj_sect, rtems_rtl_unresolv_block
- linkmap : rtems_rtl_obj
- links : _rtems_rfs_inode
- LinNumberOfImagePages : RTEMS_PACKED
- LinRedFieldPosition : RTEMS_PACKED
- LinRedMaskSize : RTEMS_PACKED
- LinRsvdFieldPosition : RTEMS_PACKED
- LinRsvdMaskSize : RTEMS_PACKED
- lo : bsp_tlb_entry_t
- load : rtems_rtl_loader_table
- LOAD : SysTick_Type
- load_order : rtems_rtl_obj_sect
- loader : rtems_rtl_obj
- loads : _rtems_rfs_inode_handle
- local_size : rtems_rtl_obj
- local_syms : rtems_rtl_obj
- local_table : Objects_Information, rtems_rtl_obj
- lock : rtems_bdbuf_cache, rtems_fdt_data, rtems_flashdisk, rtems_nvdisk, rtems_rap_data_s, rtems_rtl_data, rtems_stdio_redirect
- Lock_context : Thread_queue_Context, Thread_queue_Lock_context
- lock_line_en : L2CC
- login_buffer : rtems_user_env_t
- login_check : rtems_telnetd_config_table
- Lookup_node : POSIX_Keys_Key_value_pair
- loopback : DacCmd
- lower_wrprot_block : ALT_QSPI_DEV_SIZE_CONFIG_s
- lru : rtems_bdbuf_cache
- lsb_first : spi_bus
- LSR : DWT_Type, ITM_Type
- LSUCNT : DWT_Type
