RTEMS 5.2
Freechain Handler API. More...
| struct | Freechain_Control |
| The freechain control. More... | |
Typedefs | |
| typedef void *(* | Freechain_Allocator) (size_t size) |
| Allocator function. | |
| RTEMS_INLINE_ROUTINE void | _Freechain_Initialize (Freechain_Control *freechain, void *initial_nodes, size_t number_nodes, size_t node_size) |
| Initializes a freechain. More... | |
| RTEMS_INLINE_ROUTINE bool | _Freechain_Is_empty (const Freechain_Control *freechain) |
| Return true if the freechain is empty, otherwise false. More... | |
| RTEMS_INLINE_ROUTINE void * | _Freechain_Pop (Freechain_Control *freechain) |
| Pop an item from the freechain. More... | |
| void * | _Freechain_Extend (Freechain_Control *freechain, Freechain_Allocator allocator, size_t number_nodes_to_extend, size_t node_size) |
| Extend the freechain with new nodes. More... | |
| void * | _Freechain_Get (Freechain_Control *freechain, Freechain_Allocator allocator, size_t number_nodes_to_extend, size_t node_size) |
| Gets a node from the freechain. More... | |
| void | _Freechain_Put (Freechain_Control *freechain, void *node) |
| Puts a node back onto the freechain. More... | |
