RTEMS 5.2
Initialization Manager. More...
#include <rtems/config.h>#include <rtems/extensionimpl.h>#include <rtems/init.h>#include <rtems/sysinit.h>#include <rtems/score/sysstate.h>#include <rtems/score/copyrt.h>#include <rtems/score/heap.h>#include <rtems/score/interr.h>#include <rtems/score/isr.h>#include <rtems/score/percpudata.h>#include <rtems/score/priority.h>#include <rtems/score/schedulerimpl.h>#include <rtems/score/smpimpl.h>#include <rtems/score/timecounter.h>#include <rtems/score/threadimpl.h>#include <rtems/score/todimpl.h>#include <rtems/score/wkspace.h>Functions | |
| RTEMS_SECTION (".rtemsroset.copyright") const | |
| RTEMS_LINKER_RWSET (_Per_CPU_Data, char) | |
| RTEMS_LINKER_ROSET (_Sysinit, rtems_sysinit_item) | |
| RTEMS_SYSINIT_ITEM (rtems_initialize_data_structures, RTEMS_SYSINIT_DATA_STRUCTURES, RTEMS_SYSINIT_ORDER_MIDDLE) | |
| RTEMS_SYSINIT_ITEM (_Thread_Create_idle, RTEMS_SYSINIT_IDLE_THREADS, RTEMS_SYSINIT_ORDER_MIDDLE) | |
| void | rtems_initialize_executive (void) |
| Initializes the system and starts multitasking. More... | |
| void rtems_initialize_executive | ( | void | ) |
Iterates through the system initialization linker set and invokes the registered handlers. The final step is to start multitasking.
This directive should be called by boot_card() only.
This directive does not return.
