RTEMS 5.2
| struct | __rtems_irq_connect_data__ |
| struct | rtems_irq_global_settings |
Typedefs | |
| typedef unsigned char | rtems_irq_prio |
| typedef unsigned int | rtems_irq_number |
| typedef void * | rtems_irq_hdl_param |
| typedef void(* | rtems_irq_hdl) (rtems_irq_hdl_param) |
| typedef void(* | rtems_irq_enable) (const struct __rtems_irq_connect_data__ *) |
| typedef void(* | rtems_irq_disable) (const struct __rtems_irq_connect_data__ *) |
| typedef int(* | rtems_irq_is_enabled) (const struct __rtems_irq_connect_data__ *) |
| typedef struct __rtems_irq_connect_data__ | rtems_irq_connect_data |
| int | BSP_install_rtems_irq_handler (const rtems_irq_connect_data *) |
| int | BSP_get_current_rtems_irq_handler (rtems_irq_connect_data *ptr) |
| int | BSP_remove_rtems_irq_handler (const rtems_irq_connect_data *) |
| int | BSP_rtems_int_connect (rtems_irq_number n, rtems_irq_hdl hdl, rtems_irq_hdl_param p) |
| int | BSP_rtems_int_disconnect (rtems_irq_number n, rtems_irq_hdl hdl, rtems_irq_hdl_param p) |
| int | BSP_rtems_irq_mngt_set (rtems_irq_global_settings *config) |
| int | BSP_rtems_irq_mngt_get (rtems_irq_global_settings **) |
This include file describe the data structure and the functions implemented by rtems to write interrupt handlers.
| int BSP_get_current_rtems_irq_handler | ( | rtems_irq_connect_data * | cd | ) |
| int BSP_install_rtems_irq_handler | ( | const rtems_irq_connect_data * | cd | ) |
| int BSP_remove_rtems_irq_handler | ( | const rtems_irq_connect_data * | cd | ) |
| int BSP_rtems_irq_mngt_get | ( | rtems_irq_global_settings ** | config | ) |
| int BSP_rtems_irq_mngt_set | ( | rtems_irq_global_settings * | config | ) |
