RTEMS 5.2
#include "chip.h"#include <stdint.h>Go to the source code of this file.
| void | RTC_SetHourMode (Rtc *pRtc, uint32_t dwMode) |
| Sets the RTC in either 12 or 24 hour mode. More... | |
| uint32_t | RTC_GetHourMode (Rtc *pRtc) |
| Gets the RTC mode. More... | |
| void | RTC_EnableIt (Rtc *pRtc, uint32_t dwSources) |
| Enables the selected interrupt sources of the RTC. More... | |
| void | RTC_DisableIt (Rtc *pRtc, uint32_t dwSources) |
| Disables the selected interrupt sources of the RTC. More... | |
| int | RTC_SetTime (Rtc *pRtc, uint8_t ucHour, uint8_t ucMinute, uint8_t ucSecond) |
| Sets the current time in the RTC. More... | |
| void | RTC_GetTime (Rtc *pRtc, uint8_t *pucHour, uint8_t *pucMinute, uint8_t *pucSecond) |
| Retrieves the current time as stored in the RTC in several variables. More... | |
| int | RTC_SetTimeAlarm (Rtc *pRtc, uint8_t *pucHour, uint8_t *pucMinute, uint8_t *pucSecond) |
| Sets a time alarm on the RTC. The match is performed only on the provided variables; Setting all pointers to 0 disables the time alarm. More... | |
| void | RTC_GetDate (Rtc *pRtc, uint16_t *pwYear, uint8_t *pucMonth, uint8_t *pucDay, uint8_t *pucWeek) |
| Retrieves the current year, month and day from the RTC. Month, day and week values are numbered starting at 1. More... | |
| int | RTC_SetDate (Rtc *pRtc, uint16_t wYear, uint8_t ucMonth, uint8_t ucDay, uint8_t ucWeek) |
| Sets the current year, month and day in the RTC. Month, day and week values must be numbered starting from 1. More... | |
| int | RTC_SetDateAlarm (Rtc *pRtc, uint8_t *pucMonth, uint8_t *pucDay) |
| Sets a date alarm in the RTC. The alarm will match only the provided values; Passing a null-pointer disables the corresponding field match. More... | |
| void | RTC_ClearSCCR (Rtc *pRtc, uint32_t dwMask) |
| Clear flag bits of status clear command register in the RTC. More... | |
| uint32_t | RTC_GetSR (Rtc *pRtc, uint32_t dwMask) |
| Get flag bits of status register in the RTC. More... | |
Interface for Real Time Clock (RTC) controller.
| void RTC_ClearSCCR | ( | Rtc * | pRtc, |
| uint32_t | dwMask | ||
| mask | Bits mask of cleared events |
| void RTC_DisableIt | ( | Rtc * | pRtc, |
| uint32_t | dwSources | ||
| sources | Interrupt sources to disable. |
| void RTC_EnableIt | ( | Rtc * | pRtc, |
| sources | Interrupt sources to enable. |
| void RTC_GetDate | ( | Rtc * | pRtc, |
| uint16_t * | pwYear, | ||
| uint8_t * | pucMonth, | ||
| uint8_t * | pucDay, | ||
| uint8_t * | pucWeek | ||
| pYwear | Current year (optional). |
| pucMonth | Current month (optional). |
| pucDay | Current day (optional). |
| pucWeek | Current day in current week (optional). |
| uint32_t RTC_GetHourMode | ( | Rtc * | pRtc | ) |
Gets the RTC mode.
| uint32_t RTC_GetSR | ( | Rtc * | pRtc, |
| mask | Bits mask of Status Register |
| void RTC_GetTime | ( | Rtc * | pRtc, |
| uint8_t * | pucHour, | ||
| uint8_t * | pucMinute, | ||
| uint8_t * | pucSecond | ||
| pucHour | If not null, current hour is stored in this variable. |
| pucMinute | If not null, current minute is stored in this variable. |
| pucSecond | If not null, current second is stored in this variable. |
| int RTC_SetDate | ( | Rtc * | pRtc, |
| uint16_t | wYear, | ||
| uint8_t | ucMonth, | ||
| uint8_t | ucDay, | ||
| uint8_t | ucWeek | ||
| wYear | Current year. |
| ucMonth | Current month. |
| ucDay | Current day. |
| ucWeek | Day number in current week. |
| int RTC_SetDateAlarm | ( | Rtc * | pRtc, |
| uint8_t * | pucDay | ||
| pucMonth | If not null, the RTC alarm will month-match this value. |
| pucDay | If not null, the RTC alarm will day-match this value. |
| void RTC_SetHourMode | ( | Rtc * | pRtc, |
| uint32_t | dwMode | ||
| mode | Hour mode. |
| int RTC_SetTime | ( | Rtc * | pRtc, |
| uint8_t | ucHour, | ||
| uint8_t | ucMinute, | ||
| uint8_t | ucSecond | ||
| ucHour | Current hour in 12 or 24 hour mode. |
| ucMinute | Current minute. |
| ucSecond | Current second. |
| int RTC_SetTimeAlarm | ( | Rtc * | pRtc, |
| pucHour | If not null, the time alarm will hour-match this value. |
| pucMinute | If not null, the time alarm will minute-match this value. |
| pucSecond | If not null, the time alarm will second-match this value. |
