RTEMS 5.2
| uint32_t | Afe_ConfigureDma (AfeDma *pAfed, Afec *pAfeHw, uint8_t AfeId, sXdmad *pXdmad) |
| Initializes the AfeDma structure and the corresponding AFE & DMA . hardware select value. The driver will uses DMA channel 0 for RX . The DMA channels are freed automatically when no DMA command processing. More... | |
| uint32_t | Afe_SendData (AfeDma *pAfed, AfeCmd *pCommand) |
| Starts a AFE transfer. This is a non blocking function. It will return as soon as the transfer is started. More... | |
| pAfed | Pointer to a AfeDma instance. |
| pAfeHw | Associated Afe peripheral. |
| AfeId | Afe peripheral identifier. |
| pDmad | Pointer to a Dmad instance. |
| pCommand | Pointer to the Afe command to execute. |
