Termios device handler.
More...
#include <termiostypes.h>
| bool(* | first_open )(struct rtems_termios_tty *tty, rtems_termios_device_context *context, struct termios *term, rtems_libio_open_close_args_t *args) |
| | First open of this device. More...
| void(* | last_close )(struct rtems_termios_tty *tty, rtems_termios_device_context *context, rtems_libio_open_close_args_t *args) |
| | Last close of this device. More...
| int(* | poll_read )(rtems_termios_device_context *context) |
| | Polled read. More...
| void(* | write )(rtems_termios_device_context *context, const char *buf, size_t len) |
| | Polled write in case mode is TERMIOS_POLLED or write support otherwise. More...
| bool(* | set_attributes )(rtems_termios_device_context *context, const struct termios *term) |
| | Set attributes after a Termios settings change. More...
| int(* | ioctl )(rtems_termios_device_context *context, ioctl_command_t request, void *buffer) |
| | IO control handler. More...
rtems_termios_device_mode | mode |
| | Termios device mode.
- See also
- rtems_termios_device_install().
◆ first_open
- Parameters
| [in] | tty | The Termios control. This parameter may be passed to interrupt service routines since it must be provided for the rtems_termios_enqueue_raw_characters() and rtems_termios_dequeue_characters() functions. |
| [in] | context | The Termios device context. |
| [in] | term | The current Termios attributes. |
| [in] | args | The open/close arguments. This is parameter provided to support legacy drivers. It must not be used by new drivers. |
- Return values
| true | Successful operation. |
| false | Cannot open device. |
- See also
- rtems_termios_get_device_context() and rtems_termios_set_best_baud().
◆ ioctl
IO control handler.
Invoked in case the Termios layer cannot deal with the IO request.
- Parameters
| [in] | request | The IO control request. |
| [in] | buffer | The IO control buffer. |
◆ last_close
- Parameters
| [in] | tty | The Termios control. |
◆ poll_read
Polled read.
In case mode is TERMIOS_IRQ_DRIVEN, TERMIOS_IRQ_SERVER_DRIVEN or TERMIOS_TASK_DRIVEN, then data is received via rtems_termios_enqueue_raw_characters().
- Parameters
- Return values
| char | The received data encoded as unsigned char. |
| -1 | No data currently available. |
◆ set_attributes
- Parameters
| [in] | term | The new Termios attributes. |
- Return values
| false | Invalid attributes. |
◆ write
- Parameters
| [in] | buf | The output buffer. |
| [in] | len | The output buffer length in characters. |
