RTEMS
5.1
Data Fields | |
| rtems_rtl_obj_sect * | sect |
| const char * | name |
| int | index |
| uint32_t | mask |
| unsigned int | flags |
Section finder iterator data.
| unsigned int rtems_rtl_obj_sect_finder::flags |
The flags to use when matching.
| int rtems_rtl_obj_sect_finder::index |
The index to match.
| uint32_t rtems_rtl_obj_sect_finder::mask |
The mask to match.
| const char* rtems_rtl_obj_sect_finder::name |
The name to match.
| rtems_rtl_obj_sect* rtems_rtl_obj_sect_finder::sect |
The matching section.
1.8.15
