RTEMS
5.1
#include <object.h>
Data Fields | |
| rtems_id | minimum_id |
| rtems_id | maximum_id |
| uint32_t | maximum |
| bool | auto_extend |
| uint32_t | unallocated |
This structure is used to return information to the application about the objects configured for a specific API/Class combination.
| bool rtems_object_api_class_information::auto_extend |
This field indicates if the class is configured for auto-extend.
| uint32_t rtems_object_api_class_information::maximum |
This field is the number of object instances configured for this class.
| rtems_id rtems_object_api_class_information::maximum_id |
This field is the maximum valid object Id for this class.
| rtems_id rtems_object_api_class_information::minimum_id |
This field is the minimum valid object Id for this class.
| uint32_t rtems_object_api_class_information::unallocated |
This field is the number of currently unallocated objects.
1.8.15
