RTEMS
5.1
#include <tasks.h>
Data Fields | |
| rtems_name | name |
| size_t | stack_size |
| rtems_task_priority | initial_priority |
| rtems_attribute | attribute_set |
| rtems_task_entry | entry_point |
| rtems_mode | mode_set |
| rtems_task_argument | argument |
The following records define the Initialization Tasks Table. Each entry contains the information required by RTEMS to create and start a user task automatically at executive initialization time.
| rtems_task_argument rtems_initialization_tasks_table::argument |
This is the Initialization Task's argument.
| rtems_attribute rtems_initialization_tasks_table::attribute_set |
This is the Initialization Task's attributes.
| rtems_task_entry rtems_initialization_tasks_table::entry_point |
This is the Initialization Task's entry point.
| rtems_task_priority rtems_initialization_tasks_table::initial_priority |
This is the Initialization Task's priority.
| rtems_mode rtems_initialization_tasks_table::mode_set |
This is the Initialization Task's initial mode.
| rtems_name rtems_initialization_tasks_table::name |
This is the Initialization Task's name.
| size_t rtems_initialization_tasks_table::stack_size |
This is the Initialization Task's stack size.
1.8.15
