RTEMS
5.1
#include <ofw_tree.h>
Data Fields | |
| struct ofw_tree_node * | parent |
| struct ofw_tree_node * | peer |
| struct ofw_tree_node * | child |
| uint32_t | node_handle |
| char * | da_name |
| unsigned int | properties |
| ofw_tree_property_t * | property |
| void * | device |
Memory representation of OpenFirmware device tree node.
| char * ofw_tree_node::da_name |
Disambigued name.
| void * ofw_tree_node::device |
Member used solely by the kernel.
Pointer to a structure representing respective device. Its semantics is device dependent.
| uint32_t ofw_tree_node::node_handle |
Old OpenFirmware node handle.
| unsigned int ofw_tree_node::properties |
Number of properties.
1.8.15
