RTEMS
5.1
LibI2C bus driver entry. More...
#include <dspi.h>
Data Fields | |
| rtems_libi2c_bus_t | bus |
| Standard bus driver fields. | |
| unsigned | table_index |
| Index in the bus table: mpc55xx_dspi_bus_table. | |
| unsigned | bus_number |
| Bus number (available after rtems_libi2c_register_bus()). More... | |
| volatile struct DSPI_tag * | regs |
| Hardware registers. | |
| bool | master |
| Selects SPI master or slave mode. | |
| union DSPI_PUSHR_tag | push_data |
| Data for the Push Register. | |
| mpc55xx_dspi_edma_entry | edma_transmit |
| eDMA entry for transmission. More... | |
| mpc55xx_dspi_edma_entry | edma_push |
| eDMA entry for push data generation. More... | |
| mpc55xx_dspi_edma_entry | edma_receive |
| eDMA entry for receiving. More... | |
| uint32_t | idle_char |
| Idle character transmitted in read only mode. | |
| uint32_t | baud |
| Current baud. | |
| unsigned mpc55xx_dspi_bus_entry::bus_number |
| mpc55xx_dspi_edma_entry mpc55xx_dspi_bus_entry::edma_push |
You can choose every available channel.
| mpc55xx_dspi_edma_entry mpc55xx_dspi_bus_entry::edma_receive |
The channel is fixed to a particular DSPI.
| mpc55xx_dspi_edma_entry mpc55xx_dspi_bus_entry::edma_transmit |
1.8.15
