RTEMS
5.1
Information required to manage a thread while it is blocked. More...
#include <thread.h>
Data Fields | |
| uint32_t | count |
| void * | return_argument |
| Thread_Wait_information_Object_argument_type | return_argument_second |
| uint32_t | option |
| uint32_t | return_code |
| Thread_Wait_flags | flags |
| This field contains several flags used to control the wait class and state of a thread in case fine-grained locking is used. | |
| Thread_queue_Queue * | queue |
| The current thread queue. More... | |
| const Thread_queue_Operations * | operations |
| The current thread queue operations. More... | |
| Thread_queue_Heads * | spare_heads |
This contains the information required to manage a thread while it is blocked and to return information to it.
| uint32_t Thread_Wait_information::count |
This field is used to return an integer while when blocked.
| const Thread_queue_Operations* Thread_Wait_information::operations |
This field is protected by the thread lock wait default lock.
| uint32_t Thread_Wait_information::option |
This field contains any options in effect on this blocking operation.
| Thread_queue_Queue* Thread_Wait_information::queue |
If this field is NULL the thread is not enqueued on a thread queue. This field is protected by the thread wait default lock.
| void* Thread_Wait_information::return_argument |
This field is for a pointer to a user return argument.
| Thread_Wait_information_Object_argument_type Thread_Wait_information::return_argument_second |
This field is for a pointer to a second user return argument.
| uint32_t Thread_Wait_information::return_code |
This field will contain the return status from a blocking operation.
1.8.15
