RTEMS
5.1
RTEMS Run-Time Link Editor. More...
#include <errno.h>#include <fcntl.h>#include <inttypes.h>#include <stdlib.h>#include <string.h>#include <stdio.h>#include <unistd.h>#include <rtems/rtl/rtl.h>#include "rtl-elf.h"#include "rtl-error.h"#include <rtems/rtl/rtl-trace.h>#include "rtl-trampoline.h"#include "rtl-unwind.h"#include <rtems/rtl/rtl-unresolved.h>Data Structures | |
| struct | rtems_rtl_elf_reloc_data |
| struct | rtems_rtl_elf_common_data |
| struct | rtems_rtl_tramp_data |
| #define | REL_R_OFFSET (0) |
| #define | REL_R_INFO (1) |
| #define | REL_R_ADDEND (2) |
| #define | SEPARATED_PREFIX(_p) { _p, sizeof (_p) - 1 } |
Typedefs | |
| typedef bool(* | rtems_rtl_elf_reloc_handler) (rtems_rtl_obj *obj, bool is_rela, void *relbuf, rtems_rtl_obj_sect *targetsect, rtems_rtl_obj_sym *symbol, Elf_Sym *sym, const char *symname, Elf_Word symvalue, bool resolved, void *data) |
| typedef struct rtems_rtl_tramp_data | rtems_rtl_tramp_data |
| bool | rtems_rtl_obj_relocate_unresolved (rtems_rtl_unresolv_reloc *reloc, rtems_rtl_obj_sym *sym) |
| bool | rtems_rtl_elf_file_check (rtems_rtl_obj *obj, int fd) |
| bool | rtems_rtl_elf_file_load (rtems_rtl_obj *obj, int fd) |
| bool | rtems_rtl_elf_file_unload (rtems_rtl_obj *obj) |
| rtems_rtl_loader_format * | rtems_rtl_elf_file_sig (void) |
This is the RTL implementation.
| #define REL_R_OFFSET (0) |
The offsets in the reloc words.
| typedef bool(* rtems_rtl_elf_reloc_handler) (rtems_rtl_obj *obj, bool is_rela, void *relbuf, rtems_rtl_obj_sect *targetsect, rtems_rtl_obj_sym *symbol, Elf_Sym *sym, const char *symname, Elf_Word symvalue, bool resolved, void *data) |
Relocation worker routine.
| typedef struct rtems_rtl_tramp_data rtems_rtl_tramp_data |
Struct to handle trampoline reloc recs in the unresolved table.
| bool rtems_rtl_elf_file_check | ( | rtems_rtl_obj * | obj, |
| int | fd | ||
The ELF format check handler.
| obj | The object being checked. |
| fd | The file descriptor. |
| bool rtems_rtl_elf_file_load | ( | rtems_rtl_obj * | obj, |
| int | fd | ||
The ELF format load handler.
| obj | The object to load. |
| rtems_rtl_loader_format* rtems_rtl_elf_file_sig | ( | void | ) |
The ELF format signature handler.
| bool rtems_rtl_elf_file_unload | ( | rtems_rtl_obj * | obj | ) |
The ELF format unload handler.
| obj | The object to unload. |
| bool rtems_rtl_obj_relocate_unresolved | ( | rtems_rtl_unresolv_reloc * | reloc, |
| rtems_rtl_obj_sym * | sym | ||
Relocate an object file's unresolved reference.
| rec | The unresolved relocation record. |
| sym | The unresolved relocation's referenced symbol. |
| true | The object file record was relocated. |
| false | The relocation failed. The RTL error is set. |
1.8.15
