RTEMS
5.1
RTEMS Run-Time Linker Archive. More...
| struct | rtems_rtl_archive_symbol |
| struct | rtems_rtl_archive_symbols |
| struct | rtems_rtl_archive |
| struct | rtems_rtl_archives |
| #define | RTEMS_RTL_ARCHIVE_USER_LOAD (1 << 0) |
| #define | RTEMS_RTL_ARCHIVE_REMOVE (1 << 1) |
| #define | RTEMS_RTL_ARCHIVE_LOAD (1 << 2) |
Typedefs | |
| typedef enum rtems_rtl_archive_search | rtems_rtl_archive_search |
| typedef struct rtems_rtl_archive_symbol | rtems_rtl_archive_symbol |
| typedef struct rtems_rtl_archive_symbols | rtems_rtl_archive_symbols |
| typedef struct rtems_rtl_archive | rtems_rtl_archive |
| typedef struct rtems_rtl_archives | rtems_rtl_archives |
| typedef void(* | rtems_rtl_archive_error) (int num, const char *text) |
Enumerations | |
| enum | rtems_rtl_archive_search { rtems_rtl_archive_search_not_found = 0, rtems_rtl_archive_search_found = 1, rtems_rtl_archive_search_loaded = 2, rtems_rtl_archive_search_error = 3, rtems_rtl_archive_search_no_config = 4 } |
| void | rtems_rtl_archives_open (rtems_rtl_archives *archives, const char *config) |
| void | rtems_rtl_archives_close (rtems_rtl_archives *archives) |
| bool | rtems_rtl_archives_refresh (rtems_rtl_archives *archives) |
| bool | rtems_rtl_archive_load (rtems_rtl_archives *archives, const char *name) |
| rtems_rtl_archive_search | rtems_rtl_archive_obj_load (rtems_rtl_archives *archives, const char *symbol, bool load) |
| bool | rtems_rtl_obj_archive_find_obj (int fd, size_t fsize, const char **name, off_t *offset, size_t *size, off_t *extended_names, rtems_rtl_archive_error error) |
The RTL Archive module manages dependent loading of object files from archives. The archives need to have a ranlib generated symbol table.
This module reads a configuration file called rtl-libs.conf from a default directory of /etc. The file is a line per glob'ed path to archives to search for symbols.
The archive symbols are held in a per archive cache for searching.
| #define RTEMS_RTL_ARCHIVE_LOAD (1 << 2) |
Load the achive.
| #define RTEMS_RTL_ARCHIVE_REMOVE (1 << 1) |
The achive is not found.
| #define RTEMS_RTL_ARCHIVE_USER_LOAD (1 << 0) |
Flags for archives.User forced load.
| typedef struct rtems_rtl_archive rtems_rtl_archive |
RTL Archive data.
| typedef void(* rtems_rtl_archive_error) (int num, const char *text) |
Error handler call when finding an archive.
| typedef enum rtems_rtl_archive_search rtems_rtl_archive_search |
Symbol search and loading results.
| typedef struct rtems_rtl_archive_symbol rtems_rtl_archive_symbol |
RTL Archive symbols.
| typedef struct rtems_rtl_archive_symbols rtems_rtl_archive_symbols |
| typedef struct rtems_rtl_archives rtems_rtl_archives |
RTL Archive data.
| bool rtems_rtl_archive_load | ( | rtems_rtl_archives * | archives, |
| const char * | name | ||
Load an archive.
| archives | The archives data to search. |
| name | The archive to load. |
| true | The archive is loaded. |
| rtems_rtl_archive_search rtems_rtl_archive_obj_load | ( | rtems_rtl_archives * | archives, |
| const char * | symbol, | ||
| bool | load | ||
Search for a symbol and load the first object file that has the symbol.
| symbol | The symbol name to search for. |
| load | If @true load the object file the symbol is found in else return the found not found status. |
| void rtems_rtl_archives_close | ( | rtems_rtl_archives * | archives | ) |
Close the RTL archives support.
| archives | The archives data to close. |
| void rtems_rtl_archives_open | ( | rtems_rtl_archives * | archives, |
| const char * | config | ||
Open the RTL archives support with the specified configration file.
| archives | The archives data to open. |
| config | The path to the configuration file. |
| bool rtems_rtl_archives_refresh | ( | rtems_rtl_archives * | archives | ) |
Refresh the archives data. Check if the configuration has changes and if it has reload it. Check each path in the configuration and creates archive instances for new archives and remove archives not present any more.
Refreshing is a development aid so reboots can be avoided as users trial configurations that work.
| archives | The archives data to refresh. |
| false | The refresh failed, an error will have been set. |
| bool rtems_rtl_obj_archive_find_obj | ( | int | fd, |
| size_t | fsize, | ||
| const char ** | name, | ||
| off_t * | offset, | ||
| size_t * | size, | ||
| off_t * | extended_names, | ||
| rtems_rtl_archive_error | error | ||
Find a module in an archive returning the offset in the archive and the size. If the name field is pointing to a string pointer and that poniter is NULL and the offset is valid the name is extracted from the archive and filled in. This is used when loading a file from the archive after a symbol is found. The file name is not know and could be extended which requires searching the extended string table in the archive.
| fd | Open file handle for the archive. |
| fsize | Size of the archive. @paarm name Pointer to the name string. |
| offset | The offset of the file in the archive. |
| size | The size of the file in the archive. |
| extended_names | The offset in the archive for the extended names. |
| error | The error handler called on an error. |
| true | The file was found in the archive. |
| false | The file was not found. |
1.8.15
