RTEMS
5.1
Real mode interrupt call implementation. More...
| struct | RTEMS_PACKED |
| Used for passing and retrieving registers content to/from real mode interrupt call. More... | |
| void * | i386_get_default_rm_buffer (uint16_t *size) |
| Returns buffer and its size usable with real mode interrupt call. More... | |
| int | i386_real_interrupt_call (uint8_t interrupt_number, i386_realmode_interrupt_registers *ir) |
| Call to real mode interrupt with specified int NO and processor registers. More... | |
| void* i386_get_default_rm_buffer | ( | uint16_t * | size | ) |
Provides position to real mode buffer. It is buffer accessible from real mode context - it is located below address ~0x100000 in order for it to be accessible This buffer is meant to be pointed to by segReg:GenPurpReg and through this get bigger portion of an information to/from interrupt service routine than just by using register.
| [out] | size | pointer to variable, where the size of buffer will be filled |
| pointer | to buffer |
| int i386_real_interrupt_call | ( | uint8_t | interrupt_number, |
| i386_realmode_interrupt_registers * | ir | ||
This function allows calling interrupts in real mode and to set processor registers as desired before interrupt call is made and to retrieve the registers content after call was made.
| [in] | interrupt_number | interrupt number to be called |
| [in] | ir | pointer to structure containing registers to be passed to interrupt and to retrieve register content after call was made. |
| 0 | call failed (GDT too small or pagin is on) |
| 1 | call successful |
1.8.15
