RTEMS
5.1
Private Inlined Routines for POSIX Message Queue. More...
#include <rtems/posix/mqueue.h>#include <rtems/posix/posixapi.h>#include <rtems/score/coremsgimpl.h>#include <rtems/score/threadqimpl.h>#include <rtems/seterr.h>Go to the source code of this file.
| void | _POSIX_Message_queue_Delete (POSIX_Message_queue_Control *the_mq, Thread_queue_Context *queue_context) |
| Delete a POSIX Message Queue. More... | |
| ssize_t | _POSIX_Message_queue_Receive_support (mqd_t mqdes, char *msg_ptr, size_t msg_len, unsigned int *msg_prio, const struct timespec *abstime, Thread_queue_Enqueue_callout enqueue_callout) |
| int | _POSIX_Message_queue_Send_support (mqd_t mqdes, const char *msg_ptr, size_t msg_len, unsigned int msg_prio, const struct timespec *abstime, Thread_queue_Enqueue_callout enqueue_callout) |
| POSIX Message Queue Send Support. More... | |
| RTEMS_INLINE_ROUTINE POSIX_Message_queue_Control * | _POSIX_Message_queue_Allocate_unprotected (void) |
| RTEMS_INLINE_ROUTINE void | _POSIX_Message_queue_Free (POSIX_Message_queue_Control *the_mq) |
| POSIX Message Queue Free. More... | |
| RTEMS_INLINE_ROUTINE POSIX_Message_queue_Control * | _POSIX_Message_queue_Get (Objects_Id id, Thread_queue_Context *queue_context) |
| RTEMS_INLINE_ROUTINE CORE_message_queue_Submit_types | _POSIX_Message_queue_Priority_to_core (unsigned int priority) |
| RTEMS_INLINE_ROUTINE unsigned int | _POSIX_Message_queue_Priority_from_core (CORE_message_queue_Submit_types priority) |
| RTEMS_INLINE_ROUTINE void | _POSIX_Message_queue_Namespace_remove (POSIX_Message_queue_Control *the_mq) |
| POSIX Message Queue Remove from Namespace. | |
| RTEMS_INLINE_ROUTINE POSIX_Message_queue_Control * | _POSIX_Message_queue_Get_by_name (const char *name, size_t *name_length_p, Objects_Get_by_name_error *error) |
This include file contains the static inline implementation of the private inlined routines for POSIX Message Queue.
| void _POSIX_Message_queue_Delete | ( | POSIX_Message_queue_Control * | the_mq, |
| Thread_queue_Context * | queue_context | ||
This routine supports the mq_unlink and mq_close routines by doing most of the work involved with removing a message queue.
| RTEMS_INLINE_ROUTINE void _POSIX_Message_queue_Free | ( | POSIX_Message_queue_Control * | the_mq | ) |
This routine frees a message queue control block to the inactive chain of free message queue control blocks.
| int _POSIX_Message_queue_Send_support | ( | mqd_t | mqdes, |
| const char * | msg_ptr, | ||
| size_t | msg_len, | ||
| unsigned int | msg_prio, | ||
| const struct timespec * | abstime, | ||
| Thread_queue_Enqueue_callout | enqueue_callout | ||
This routine posts a message to a specified message queue.
1.8.15
