| RTEMS_INLINE_ROUTINE Timer_Control * | _Timer_Allocate (void) |
| | Timer_Allocate. More...
| RTEMS_INLINE_ROUTINE void | _Timer_Free (Timer_Control *the_timer) |
| | Timer_Free. More...
RTEMS_INLINE_ROUTINE Timer_Control * | _Timer_Get (Objects_Id id, ISR_lock_Context *lock_context) |
RTEMS_INLINE_ROUTINE Per_CPU_Control * | _Timer_Acquire_critical (Timer_Control *the_timer, ISR_lock_Context *lock_context) |
RTEMS_INLINE_ROUTINE void | _Timer_Release (Per_CPU_Control *cpu, ISR_lock_Context *lock_context) |
RTEMS_INLINE_ROUTINE bool | _Timer_Is_interval_class (Timer_Classes the_class) |
RTEMS_INLINE_ROUTINE bool | _Timer_Is_on_task_class (Timer_Classes the_class) |
RTEMS_INLINE_ROUTINE Per_CPU_Watchdog_index | _Timer_Watchdog_header_index (Timer_Classes the_class) |
RTEMS_INLINE_ROUTINE Watchdog_Interval | _Timer_Get_CPU_ticks (const Per_CPU_Control *cpu) |
rtems_status_code | _Timer_Fire (rtems_id id, rtems_interval interval, rtems_timer_service_routine_entry routine, void *user_data, Timer_Classes the_class, Watchdog_Service_routine_entry adaptor) |
rtems_status_code | _Timer_Fire_after (rtems_id id, rtems_interval ticks, rtems_timer_service_routine_entry routine, void *user_data, Timer_Classes the_class, Watchdog_Service_routine_entry adaptor) |
rtems_status_code | _Timer_Fire_when (rtems_id id, const rtems_time_of_day *wall_time, rtems_timer_service_routine_entry routine, void *user_data, Timer_Classes the_class, Watchdog_Service_routine_entry adaptor) |
void | _Timer_Cancel (Per_CPU_Control *cpu, Timer_Control *the_timer) |
void | _Timer_Routine_adaptor (Watchdog_Control *the_watchdog) |
void | _Timer_server_Routine_adaptor (Watchdog_Control *the_watchdog) |
RTEMS_INLINE_ROUTINE void | _Timer_server_Acquire_critical (Timer_server_Control *timer_server, ISR_lock_Context *lock_context) |
RTEMS_INLINE_ROUTINE void | _Timer_server_Release_critical (Timer_server_Control *timer_server, ISR_lock_Context *lock_context) |
