| enum | ALT_QSPI_MODE_e { ALT_QSPI_MODE_SINGLE = 0,
ALT_QSPI_MODE_DUAL = 1,
ALT_QSPI_MODE_QUAD = 2
| enum | ALT_QSPI_CS_MODE_e { ALT_QSPI_CS_MODE_SINGLE_SELECT = 0,
ALT_QSPI_CS_MODE_DECODE = 1
| enum | ALT_QSPI_BAUD_DIV_e {
ALT_QSPI_BAUD_DIV_2 = 0x0,
ALT_QSPI_BAUD_DIV_4 = 0x1,
ALT_QSPI_BAUD_DIV_6 = 0x2,
ALT_QSPI_BAUD_DIV_8 = 0x3,
ALT_QSPI_BAUD_DIV_10 = 0x4,
ALT_QSPI_BAUD_DIV_12 = 0x5,
ALT_QSPI_BAUD_DIV_14 = 0x6,
ALT_QSPI_BAUD_DIV_16 = 0x7,
ALT_QSPI_BAUD_DIV_18 = 0x8,
ALT_QSPI_BAUD_DIV_20 = 0x9,
ALT_QSPI_BAUD_DIV_22 = 0xA,
ALT_QSPI_BAUD_DIV_24 = 0xB,
ALT_QSPI_BAUD_DIV_26 = 0xC,
ALT_QSPI_BAUD_DIV_28 = 0xD,
ALT_QSPI_BAUD_DIV_30 = 0xE,
ALT_QSPI_BAUD_DIV_32 = 0xF
| enum | ALT_QSPI_CLK_PHASE_e { ALT_QSPI_CLK_PHASE_ACTIVE = 0,
ALT_QSPI_CLK_PHASE_INACTIVE = 1
| enum | ALT_QSPI_CLK_POLARITY_e { ALT_QSPI_CLK_POLARITY_LOW = 0,
ALT_QSPI_CLK_POLARITY_HIGH = 1
The declarations and functions in this group are used to configure the QSPI controller interface to external flash devices.
The following steps describe how to initialize and configure the QSPI controller to operate with a flash device.
◆ ALT_QSPI_BAUD_DIV_t
This type enumerates the QSPI controller master baud rate divisor selections.
◆ ALT_QSPI_CLK_PHASE_t
This type enumerates the QSPI clock phase activity options outside the SPI word.
◆ ALT_QSPI_CLK_POLARITY_t
This type enumerates the QSPI clock polarity options outside the SPI word.
◆ ALT_QSPI_CS_MODE_t
This type enumerates the mode configurations available for driving the ss_n[3:0] device chip selects. The chip selects may be controlled as either in a '1 of 4' or '4 to 16 decode' mode.
◆ ALT_QSPI_DEV_INST_CONFIG_t
Device Instruction Configuration
This type defines a structure for specifying the optimal instruction set configuration to use with a target flash device.
◆ ALT_QSPI_DEV_SIZE_CONFIG_t
Device Size Configuration
This type defines the structure used to specify flash device size and write protect regions.
◆ ALT_QSPI_MODE_t
This type enumerates the operational modes the QSPI controller can be configured for. It may apply to instruction, address, and/or data width interactions between the QSPI controller and the flash device.
◆ ALT_QSPI_TIMING_CONFIG_t
QSPI Controller Timing Configuration
This type defines the structure used to configure timing paramaters used by the QSPI controller to communicate with a target flash device.
All timing values are defined in cycles of the SPI master ref clock.
◆ ALT_QSPI_BAUD_DIV_e
| Enumerator |
| ALT_QSPI_BAUD_DIV_2 | Divide by 2
| ALT_QSPI_BAUD_DIV_4 | Divide by 4
| ALT_QSPI_BAUD_DIV_6 | Divide by 6
| ALT_QSPI_BAUD_DIV_8 | Divide by 8
| ALT_QSPI_BAUD_DIV_10 | Divide by 10
| ALT_QSPI_BAUD_DIV_12 | Divide by 12
| ALT_QSPI_BAUD_DIV_14 | Divide by 14
| ALT_QSPI_BAUD_DIV_16 | Divide by 16
| ALT_QSPI_BAUD_DIV_18 | Divide by 18
| ALT_QSPI_BAUD_DIV_20 | Divide by 20
| ALT_QSPI_BAUD_DIV_22 | Divide by 22
| ALT_QSPI_BAUD_DIV_24 | Divide by 24
| ALT_QSPI_BAUD_DIV_26 | Divide by 26
| ALT_QSPI_BAUD_DIV_28 | Divide by 28
| ALT_QSPI_BAUD_DIV_30 | Divide by 30
| ALT_QSPI_BAUD_DIV_32 | Divide by 32
◆ ALT_QSPI_CLK_PHASE_e
| Enumerator |
| ALT_QSPI_CLK_PHASE_ACTIVE | The SPI clock is active outside the word
| ALT_QSPI_CLK_PHASE_INACTIVE | The SPI clock is inactive outside the word
◆ ALT_QSPI_CLK_POLARITY_e
| Enumerator |
| ALT_QSPI_CLK_POLARITY_LOW | SPI clock is quiescent low outside the word.
| ALT_QSPI_CLK_POLARITY_HIGH | SPI clock is quiescent high outside the word.
◆ ALT_QSPI_CS_MODE_e
| Enumerator |
| ALT_QSPI_CS_MODE_SINGLE_SELECT | Select 1 of 4 chip select ss_n[3:0]
| ALT_QSPI_CS_MODE_DECODE | Select external 4 to 16 decode of ss_n[3:0].
◆ ALT_QSPI_MODE_e
| Enumerator |
| ALT_QSPI_MODE_SINGLE | Use Standard Single SPI (SIO-SPI) mode (bits always transferred into the device on DQ0 only). Supported by all SPI flash devices.
| ALT_QSPI_MODE_DUAL | Use Dual SPI (DIO-SPI) SPI mode where bits are transferred on DQ0 and DQ1.
| ALT_QSPI_MODE_QUAD | Use Dual SPI (QIO-SPI) SPI mode where bits are transferred on DQ0, DQ1, DQ3, and DQ3.
◆ alt_qspi_baud_rate_div_get()
Get the current value of the QSPI master baud rate divisor.
- Returns
- The value of the QSPI master baud rate divisor.
◆ alt_qspi_baud_rate_div_set()
Set the current value of the QSPI master baud rate divisor.
Sets the value of the QSPI master baud rate divisor.
- Parameters
| baud_rate_div | The master baud rate divisor. Valid range includes even values 2 to 32. |
- Return values
| ALT_E_SUCCESS | Indicates successful completion. |
| ALT_E_ERROR | Indicates an error occurred. |
◆ alt_qspi_chip_select_config_get()
Get the current QSPI device peripheral chip select output and decode function configuration values.
- Parameters
| cs | [out] The chip select line output values. |
| cs_mode | [out] The decode mode to use for the chip selects. |
- Return values
◆ alt_qspi_chip_select_config_set()
Set the QSPI device peripheral chip select outputs and decode function configuration.
The chip select lines output values operate according to the selected chip select decode mode. If cs_mode is ALT_QSPI_CS_MODE_SINGLE_SELECT then cs[3:0] are output thus:
| cs[3:0] | n_ss_out[3:0] |
| xxx0 | 1110 |
| xx01 | 1101 |
| x011 | 1011 |
| 0111 | 0111 |
| 1111 | 1111 (no peripheral selected) |
Otherwise if cs_mode is ALT_QSPI_CS_MODE_DECODE then cs[3:0] directly drives n_ss_out[3:0].
- Parameters
| cs | The chip select line output values. |
| cs_mode | The decode mode to use for the chip selects. |
- Return values
◆ alt_qspi_device_read_config_get()
Get the current QSPI device read instruction configuration.
- Parameters
| cfg | [out] Pointer to a ALT_QSPI_DEV_INST_CONFIG_t structure to contain the returned QSPI controller instruction configuration used when performing read transactions with the device. |
- Return values
◆ alt_qspi_device_read_config_set()
Set the QSPI device read instruction configuration.
This API requires that the QSPI controller be idle, as determined by alt_qspi_is_idle().
- Parameters
| cfg | Pointer to a ALT_QSPI_DEV_INST_CONFIG_t structure specifying the desired op code, transfer widths, and dummy cycles for the QSPI controller to use when performing read transactions with the device. |
- Return values
◆ alt_qspi_device_size_config_get()
Get the current flash device size and write protection configuration.
- Parameters
| cfg | [out] Pointer to a ALT_QSPI_DEV_SIZE_CONFIG_t structure to contain the returned flash device size and write protection configuration. |
- Return values
◆ alt_qspi_device_size_config_set()
Set the flash device size and write protection configuration.
- Parameters
| cfg | Pointer to a ALT_QSPI_DEV_SIZE_CONFIG_t structure containing the flash device size and write protection configuration. |
- Return values
◆ alt_qspi_device_write_config_get()
Get the current QSPI device write instruction configuration.
- Parameters
| cfg | [out] Pointer to a ALT_QSPI_DEV_INST_CONFIG_t structure to contain the returned QSPI controller instruction configuration used when performing write transactions with the device. |
- Return values
◆ alt_qspi_device_write_config_set()
Set the QSPI device write instruction configuration.
- Parameters
| cfg | Pointer to a ALT_QSPI_DEV_INST_CONFIG_t structure specifying the desired op code, transfer widths, and dummy cycles for the QSPI controller to use when performing write transactions with the device. |
- Return values
◆ alt_qspi_mode_bit_config_get()
| uint32_t alt_qspi_mode_bit_config_get |
void |
Get the current value of the Mode Bit Configuration register.
- Returns
- The 8 bit value that is sent to the device following the address bytes when the mode bit is enabled (see: alt_qspi_mode_bit_enable())
◆ alt_qspi_mode_bit_config_set()
Set the value of the Mode Bit Configuration register.
Set the value of the 8 bits that are sent to the device following the address bytes when the mode bit is enabled (see: alt_qspi_mode_bit_enable())
- Parameters
| mode_bits | The 8 bit value sent to the device following the address bytes. |
- Return values
◆ alt_qspi_mode_bit_disable()
Disable the mode bits from being sent after the address bytes.
Prevent the mode bits defined in the Mode Bit Configuration register from being sent following the address bytes.
- Return values
◆ alt_qspi_mode_bit_enable()
Enable the mode bits to be sent after the address bytes.
Ensure the mode bits defined in the Mode Bit Configuration register to be sent following the address bytes.
- Return values
◆ alt_qspi_timing_config_get()
Get the QSPI device delay and timing configuration parameters.
This function returns the settings of the chip select delay and timing configurations.
- Parameters
| cfg | [out] Pointer to a ALT_QSPI_TIMING_CONFIG_t structure to return the device timing and delay settings. |
- Return values
◆ alt_qspi_timing_config_set()
Set the QSPI device delay and timing configuration parameters.
This function allows the user to configure how the chip select is driven after each flash access. This is required as each device may have different timing requirements. As the serial clock frequency is increased, these timing parameters become more important and can be adjusted to meet the requirements of a specific flash device. All timings are defined in cycles of the SPI master ref clock.
- Parameters
| cfg | Pointer to a ALT_QSPI_TIMING_CONFIG_t structure specifying the desired timing and delay settings. |
- Return values
