#include "chip.h"
#include <stdint.h>
#define | IFLASH_SECTOR_SIZE 65536u |
#define | EFC_FCMD_GETD 0x00 /* Get Flash Descriptor */ |
#define | EFC_FCMD_WP 0x01 /* Write page */ |
#define | EFC_FCMD_WPL 0x02 /* Write page and lock */ |
#define | EFC_FCMD_EWP 0x03 /* Erase page and write page */ |
#define | EFC_FCMD_EWPL 0x04 /* Erase page and write page then lock */ |
#define | EFC_FCMD_EA 0x05 /* Erase all */ |
#define | EFC_FCMD_EPA 0x07 /* Erase pages */ |
#define | EFC_FCMD_SLB 0x08 /* Set Lock Bit */ |
#define | EFC_FCMD_CLB 0x09 /* Clear Lock Bit */ |
#define | EFC_FCMD_GLB 0x0A /* Get Lock Bit */ |
#define | EFC_FCMD_SFB 0x0B /* Set GPNVM Bit */ |
#define | EFC_FCMD_CFB 0x0C /* Clear GPNVM Bit */ |
#define | EFC_FCMD_GFB 0x0D /* Get GPNVM Bit */ |
#define | EFC_FCMD_STUI 0x0E /* Start unique ID */ |
#define | EFC_FCMD_SPUI 0x0F /* Stop unique ID */ |
#define | EFC_FCMD_GCALB 0x10 /* Get CALIB Bit */ |
#define | EFC_FCMD_ES 0x11 /* Erase Sector */ |
#define | EFC_FCMD_WUS 0x12 /* Write User Signature */ |
#define | EFC_FCMD_EUS 0x13 /* Erase User Signature */ |
#define | EFC_FCMD_STUS 0x14 /* Start Read User Signature */ |
#define | EFC_FCMD_SPUS 0x15 /* Stop Read User Signature */ |
#define | CHIP_FLASH_IAP_ADDRESS (0x00800008) |
| void | EFC_EnableFrdyIt (Efc *efc) |
| | Enables the flash ready interrupt source on the EEFC peripheral. More...
| void | EFC_DisableFrdyIt (Efc *efc) |
| | Disables the flash ready interrupt source on the EEFC peripheral. More...
| void | EFC_SetWaitState (Efc *efc, uint8_t cycles) |
| | Set read/write wait state on the EEFC peripheral. More...
| void | EFC_TranslateAddress (Efc **pEfc, uint32_t dwAddress, uint16_t *pwPage, uint16_t *pwOffset) |
| | Translates the given address page and offset values. More...
| void | EFC_ComputeAddress (Efc *efc, uint16_t wPage, uint16_t wOffset, uint32_t *pdwAddress) |
| | Computes the address of a flash access given the page and offset. More...
| uint32_t | EFC_PerformCommand (Efc *efc, uint32_t dwCommand, uint32_t dwArgument, uint32_t dwUseIAP) |
| | Performs the given command and wait until its completion (or an error). More...
| uint32_t | EFC_GetStatus (Efc *efc) |
| | Returns the current status of the EEFC. More...
| uint32_t | EFC_GetResult (Efc *efc) |
| | Returns the result of the last executed command. More...
| void | EFC_SetFlashAccessMode (Efc *efc, uint32_t dwMode) |
| | Set flash access mode. More...
Purpose
Interface for configuration the Enhanced Embedded Flash Controller (EEFC) peripheral.
Usage
- Enable/disable flash ready interrupt sources using EFC_EnableFrdyIt() and EFC_DisableFrdyIt().
- Translates the given address into which EEFC, page and offset values for difference density flash memory using EFC_TranslateAddress().
- Computes the address of a flash access given the EFC, page and offset for difference density flash memory using EFC_ComputeAddress().
- Start the executing command with EFC_PerformCommand()
- Retrieve the current status of the EFC using EFC_GetStatus().
- Retrieve the result of the last executed command with EFC_GetResult().
◆ EFC_ComputeAddress()
| void EFC_ComputeAddress |
Efc * |
efc, |
uint16_t |
wPage, |
uint16_t |
wOffset, |
uint32_t * |
pdwAddress |
- Parameters
| efc | Pointer to a Efc instance |
| page | Page number. |
| offset | Byte offset inside page. |
| pAddress | Computed address (optional). |
◆ EFC_DisableFrdyIt()
| void EFC_DisableFrdyIt |
Efc * |
efc | ) |
- Parameters
◆ EFC_EnableFrdyIt()
| void EFC_EnableFrdyIt |
Efc * |
efc | ) |
- Parameters
◆ EFC_GetResult()
| uint32_t EFC_GetResult |
Efc * |
efc | ) |
- Parameters
◆ EFC_GetStatus()
| uint32_t EFC_GetStatus |
Efc * |
efc | ) |
- Note
- Keep in mind that this function clears the value of some status bits (LOCKE, PROGE).
- Parameters
◆ EFC_PerformCommand()
| uint32_t EFC_PerformCommand |
Efc * |
efc, |
uint32_t |
dwCommand, |
uint32_t |
dwArgument, |
uint32_t |
dwUseIAP |
- Parameters
| command | Command to perform. |
| argument | Optional command argument. |
- Returns
- 0 if successful, otherwise returns an error code.
◆ EFC_SetFlashAccessMode()
| void EFC_SetFlashAccessMode |
Efc * |
efc, |
uint32_t |
dwMode |
- Parameters
| dwMode | - 0:128-bit, (1<<24):64-bit |
◆ EFC_SetWaitState()
| void EFC_SetWaitState |
Efc * |
efc, |
uint8_t |
ucCycles |
- Parameters
| cycles | the number of wait states in cycle. |
◆ EFC_TranslateAddress()
| void EFC_TranslateAddress |
Efc ** |
ppEfc, |
uint32_t |
dwAddress, |
uint16_t * |
pwPage, |
uint16_t * |
pwOffset |
- Note
- The resulting values are stored in the provided variables if they are not null.
- Parameters
| address | Address to translate. |
| pPage | First page accessed. |
| pOffset | Byte offset in first page. |
