RTEMS
5.1
SPARC64 CPU Dependent Source. More...
| void | _CPU_Initialize (void) |
| CPU initialization. More... | |
| void | _CPU_Context_Initialize (Context_Control *the_context, void *stack_base, uint32_t size, uint32_t new_level, void *entry_point, bool is_fp, void *tls_area) |
| uint32_t | _CPU_ISR_Get_level (void) |
| Returns the interrupt level of the executing thread. More... | |
| void | _CPU_ISR_install_raw_handler (uint32_t vector, CPU_ISR_raw_handler new_handler, CPU_ISR_raw_handler *old_handler) |
| SPARC specific raw ISR installer. More... | |
| void | _CPU_ISR_install_vector (uint32_t vector, CPU_ISR_handler new_handler, CPU_ISR_handler *old_handler) |
| SPARC specific RTEMS ISR installer. More... | |
| volatile uint32_t | _CPU_ISR_Dispatch_disable |
| const CPU_Trap_table_entry | _CPU_Trap_slot_template |
| const CPU_Trap_table_entry _CPU_Trap_slot_template |
This is the set of opcodes for the instructions loaded into a trap table entry. The routine which installs a handler is responsible for filling in the fields for the _handler address and the _vector trap type.
The constants following this structure are masks for the fields which must be filled in when the handler is installed.
1.8.15
