RTEMS
5.1
Blackfin CPU Dependent Source. More...
#include <rtems/score/isr.h>#include <rtems/score/wkspace.h>#include <rtems/score/bfin.h>#include <rtems/bfin/bfin.h>Functions | |
| void | _ISR15_Handler (void) |
| void | _CPU_Emulation_handler (void) |
| void | _CPU_Reset_handler (void) |
| void | _CPU_NMI_handler (void) |
| void | _CPU_Exception_handler (void) |
| void | _CPU_Unhandled_Interrupt_handler (void) |
| void | _CPU_Initialize (void) |
| CPU initialization. More... | |
| uint32_t | _CPU_ISR_Get_level (void) |
| Returns the interrupt level of the executing thread. More... | |
| void | _CPU_ISR_install_raw_handler (uint32_t vector, CPU_ISR_raw_handler new_handler, CPU_ISR_raw_handler *old_handler) |
| SPARC specific raw ISR installer. More... | |
| void | _CPU_ISR_install_vector (uint32_t vector, CPU_ISR_handler new_handler, CPU_ISR_handler *old_handler) |
| SPARC specific RTEMS ISR installer. More... | |
| void * | _CPU_Thread_Idle_body (uintptr_t ignored) |
| void | _CPU_Context_Initialize (Context_Control *the_context, uint32_t *stack_base, uint32_t size, uint32_t new_level, void *entry_point, bool is_fp, void *tls_area) |
| void _CPU_Context_Initialize | ( | Context_Control * | the_context, |
| uint32_t * | stack_base, | ||
| uint32_t | size, | ||
| uint32_t | new_level, | ||
| void * | entry_point, | ||
| bool | is_fp, | ||
| void * | tls_area | ||
Initialize the context to a state suitable for starting a task after a context restore operation. Generally, this involves:
| [in] | the_context | points to the context area |
| [in] | stack_base | is the low address of the allocated stack area |
| [in] | size | is the size of the stack area in bytes |
| [in] | new_level | is the interrupt level for the task |
| [in] | entry_point | is the task's entry point |
| [in] | is_fp | is set to TRUE if the task is a floating point task |
| [in] | tls_area | is the thread-local storage (TLS) area |
NOTE: Implemented as a subroutine for the SPARC port.
| void _CPU_ISR_install_raw_handler | ( | uint32_t | vector, |
| CPU_ISR_raw_handler | new_handler, | ||
| CPU_ISR_raw_handler * | old_handler | ||
This routine installs new_handler to be directly called from the trap table.
| [in] | vector | is the vector number |
| [in] | new_handler | is the new ISR handler |
| [in] | old_handler | will contain the old ISR handler |
1.8.15
