RTEMS
5.1
#include <rtems/capture.h>Go to the source code of this file.
| rtems_status_code | rtems_capture_cli_init (rtems_capture_timestamp timestamp) |
This is the Target Interface Command Line Interface. You need start the RTEMS monitor.
| rtems_status_code rtems_capture_cli_init | ( | rtems_capture_timestamp | timestamp | ) |
This function initialises the command line interface to the capture engine.
1.8.15
