RTEMS
5.1
CAN controller for the mbed lpc1768 board. More...
| struct | registers_can_message |
| A CAN message represented for the registers of the device. More... | |
| struct | low_level_can_message |
| A CAN message represented with each logical parts. More... | |
| struct | can_message |
| A CAN message represented of both forms. More... | |
Typedefs | |
| typedef void(* | lpc176x_can_isr) (lpc176x_can_number number) |
| An isr for a CAN interrupt. More... | |
| typedef unsigned int | can_freq |
| A CAN frequency value. | |
Enumerations | |
| enum | lpc176x_can_number { CAN_0, CAN_1, CAN_DEVICES_NUMBER } |
| The CAN devices of the board. | |
| enum | can_irq_type { IRQ_RX = 0, IRQ_TX, IRQ_ERROR, IRQ_OVERRUN, IRQ_WAKEUP, IRQ_PASSIVE, IRQ_ARB, IRQ_BUS, IRQ_READY, CAN_IRQ_NUMBER } |
| The possible interrupt sources for CAN. | |
| rtems_status_code | can_open (lpc176x_can_number minor, can_freq freq) |
| Opens CAN device. More... | |
| rtems_status_code | can_close (lpc176x_can_number minor) |
| Closes the passed CAN device and shut it down. More... | |
| rtems_status_code | can_read (const lpc176x_can_number minor, can_message *message) |
| Reads the CAN device. More... | |
| rtems_status_code | can_write (const lpc176x_can_number minor, const can_message *const message) |
| Writes the passed CAN message into the selected CAN device. More... | |
| rtems_status_code | can_register_isr (const lpc176x_can_number number, const can_irq_type type, const lpc176x_can_isr isr) |
| Registers an isr in the driver vector, and enables the interrupt in the device. More... | |
| rtems_status_code | create_can_message (can_message *const msg, const int _id, const char *const _data, const char _len) |
| Creates a CAN message. More... | |
| typedef void(* lpc176x_can_isr) (lpc176x_can_number number) |
| number | The CAN which rised the interrupt. |
| rtems_status_code can_close | ( | lpc176x_can_number | minor | ) |
| minor | The device to close. |
| rtems_status_code can_open | ( | lpc176x_can_number | minor, |
| can_freq | freq | ||
Opens CAN device.
It enables the module and gives it a clock, sets the pins, disables the interrupts, sets the frequency and bypasses the acceptance filter.
| minor | The device to open. |
| freq | The desired frequency. |
| rtems_status_code can_read | ( | const lpc176x_can_number | minor, |
| can_message * | message | ||
| minor | The CAN device to read. |
| message | The read message. |
| rtems_status_code can_register_isr | ( | const lpc176x_can_number | number, |
| const can_irq_type | type, | ||
| const lpc176x_can_isr | isr | ||
| number | The CAN device to set |
| type | The interrupt type. |
| isr | The isr to register. |
| rtems_status_code can_write | ( | const lpc176x_can_number | minor, |
| const can_message *const | message | ||
| minor | The device to write. |
| message | The message to write. |
| rtems_status_code create_can_message | ( | can_message *const | msg, |
| const int | _id, | ||
| const char *const | _data, | ||
| const char | _len | ||
[long description]
| msg | The created message. |
| _id | The can id for the message. |
| _data | The data of the message. |
| _len | The length of the message. |
1.8.15
