RTEMS
5.1
Raspberry Pi specific SPI definitions. More...
#include <rtems/libi2c.h>Go to the source code of this file.
SPI constants. | |
| #define | GPU_CORE_CLOCK_RATE 250000000 |
| GPU processor core clock rate in Hz. More... | |
SPI directives. | |
| int | rpi_spi_init (bool bidirectional_mode) |
| Setups the Raspberry Pi SPI bus (located on the GPIO header) on the "/dev/spi" device file, and registers the bus on the libi2c API. More... | |
| #define GPU_CORE_CLOCK_RATE 250000000 |
Unless configured otherwise on a "config.txt" file present on the SD card the GPU defaults to 250 MHz. Currently only 250 MHz is supported.
| int rpi_spi_init | ( | bool | bidirectional_mode | ) |
| [in] | bidirectional_mode | If TRUE sets the SPI bus to use 2-wire SPI, where the MOSI data line doubles as the slave out (SO) and slave in (SI) data lines. If FALSE the bus defaults to the usual 3-wire SPI, with 2 separate data lines (MOSI and MISO). |
| Returns | libi2c bus number. |
| <0 | Could not register the bus. See |
1.8.15
