RTEMS
5.1
Interface to Kernel Print Methods. More...
Typedefs | |
| typedef void(* | BSP_output_char_function_type) (char c) |
| typedef int(* | BSP_polling_getchar_function_type) (void) |
| int | getchark (void) |
| Get Character (kernel I/O) More... | |
| int | vprintk (const char *fmt, va_list ap) |
| Variable Argument printk() More... | |
| int | rtems_printk_printer (void *ignored, const char *format, va_list ap) |
| int | printk (const char *fmt,...) RTEMS_PRINTFLIKE(1 |
| Kernel Print. More... | |
| int int | putk (const char *s) |
| Kernel Put String. More... | |
| void | rtems_putc (char c) |
| Kernel Put Character. More... | |
| void | rtems_put_char (int c, void *arg) |
| Puts the character via rtems_putc(). More... | |
| BSP_output_char_function_type | BSP_output_char |
| BSP_polling_getchar_function_type | BSP_poll_char |
This include file defines the interface to kernel print methods.
| typedef void(* BSP_output_char_function_type) (char c) |
This type defines the prototype for the BSP provided method to print a single character. It is assumed to be polled.
| typedef int(* BSP_polling_getchar_function_type) (void) |
This type defines the prototype for the BSP provided method to input a single character. It is assumed to be polled.
| int getchark | ( | void | ) |
This method polls for a key in the simplest possible fashion from whatever the debug console device is.
| int printk | ( | const char * | fmt, |
Kernel Print.
This method allows the user to perform a debug printk(). It performs a character translation from "\n" to "\r\n".
| [in] | fmt | is a printf()-style format string |
| int int putk | ( | const char * | s | ) |
Kernel Put String.
This method allows the user to perform a debug puts().
| [in] | s | is the string to print |
Kernel putk (e.g. puts) function requiring minimal infrastrure.
| void rtems_put_char | ( | int | c, |
| void * | arg | ||
This is a compatibility function to support an internal API.
| c | The character to put. |
| arg | Ignored. |
| void rtems_putc | ( | char | c | ) |
This method allows the user to perform a debug putc(). It performs a character translation from "\n" to "\r\n".
| [in] | c | is the character to print |
| int vprintk | ( | const char * | fmt, |
| va_list | ap | ||
| BSP_output_char_function_type BSP_output_char |
This variable points to the BSP provided method to output a character for the purposes of debug output.
It must output only the specific character. It must not perform character translations, e.g. "\n" to "\r\n".
| BSP_polling_getchar_function_type BSP_poll_char |
This variable points to the BSP provided method to input a character for the purposes of debug input.
1.8.15
