RTEMS
5.1
| #define | MASK_STATUS0 0xFFFFFFFC |
| #define | MASK_STATUS1 0xFFFFFFFF |
| void | PMC_EnablePeripheral (uint32_t dwId) |
| Enables the clock of a peripheral. The peripheral ID is used to identify which peripheral is targeted. More... | |
| void | PMC_DisablePeripheral (uint32_t dwId) |
| Disables the clock of a peripheral. The peripheral ID is used to identify which peripheral is targeted. More... | |
| void | PMC_EnableAllPeripherals (void) |
| Enable all the periph clock via PMC. | |
| void | PMC_DisableAllPeripherals (void) |
| Disable all the periph clock via PMC. | |
| uint32_t | PMC_IsPeriphEnabled (uint32_t dwId) |
| Get Periph Status for the given peripheral ID. More... | |
| void | PMC_EnableExtOsc (void) |
| Enable external oscillator as main clock input. | |
| void | PMC_DisableExtOsc (void) |
| Disable external 12MHz oscillator. | |
| void | PMC_SelectExtOsc (void) |
| Select external OSC. | |
| void | PMC_SelectExtBypassOsc (void) |
| void | PMC_EnableIntRC4_8_12MHz (uint32_t freqSelect) |
| Enable internal 4/8/12MHz fast RC as main clock input. More... | |
| void | PMC_DisableIntRC4_8_12MHz (void) |
| Disable internal 4/8/12MHz fast RC. | |
| void | PMC_SetPllaClock (uint32_t mul, uint32_t div) |
| Configure PLLA clock by giving MUL and DIV. Disable PLLA when 'mul' set to 0. More... | |
| void | PMC_SetMckSelection (uint32_t clockSource, uint32_t prescaler) |
| Selection of Master Clock. More... | |
| void | PMC_DisableAllClocks (void) |
| Disable all clocks. | |
| void | PMC_ConfigureMckWithPlla (uint32_t mul, uint32_t div, uint32_t prescaler) |
| Configure PLLA as clock input for MCK. More... | |
| void | PMC_EnableXT32KFME (void) |
| void | PMC_ConfigurePCK0 (uint32_t MasterClk, uint32_t prescaler) |
| void | PMC_ConfigurePCK1 (uint32_t MasterClk, uint32_t prescaler) |
| void | PMC_ConfigurePCK2 (uint32_t MasterClk, uint32_t prescaler) |
Interface for configuring and using Power Management Controller (PMC) peripherals.
Implementation of Power Management Controller (PMC).
| void PMC_ConfigureMckWithPlla | ( | uint32_t | mul, |
| uint32_t | div, | ||
| uint32_t | prescaler | ||
| mul | PLL multiplier factor (not shifted, don't minus 1). |
| div | PLL divider factor (not shifted). |
| prescaler | Master Clock prescaler (shifted as in register). |
| void PMC_ConfigurePCK0 | ( | uint32_t | MasterClk, |
| void PMC_ConfigurePCK1 | ( | uint32_t | MasterClk, |
| void PMC_ConfigurePCK2 | ( | uint32_t | MasterClk, |
| void PMC_DisablePeripheral | ( | uint32_t | dwId | ) |
| id | Peripheral ID (ID_xxx). |
| void PMC_EnableIntRC4_8_12MHz | ( | uint32_t | freqSelect | ) |
| freqSelect | fast RC frequency (FAST_RC_4MHZ, FAST_RC_8MHZ, FAST_RC_12MHZ). |
| void PMC_EnablePeripheral | ( | uint32_t | dwId | ) |
| void PMC_EnableXT32KFME | ( | void | ) |
| uint32_t PMC_IsPeriphEnabled | ( | uint32_t | dwId | ) |
| void PMC_SetMckSelection | ( | uint32_t | clockSource, |
| clockSource | Master Clock source. |
| prescaler | Master Clock prescaler. |
| void PMC_SetPllaClock | ( | uint32_t | mul, |
| uint32_t | div | ||
| mul | PLL multiplier factor. |
| div | PLL divider factor. |
1.8.15
