RTEMS
5.1
| void | ACC_Configure (Acc *pAcc, uint8_t idAcc, uint8_t ucSelplus, uint8_t ucSelminus, uint16_t wAc_en, uint16_t wEdge, uint16_t wInvert) |
| Initialize the ACC controller. More... | |
| void | ACC_SetComparisonPair (Acc *pAcc, uint8_t ucSelplus, uint8_t ucSelminus) |
| uint32_t | ACC_GetComparisonResult (Acc *pAcc, uint32_t dwStatus) |
Implementation of Analog Comparator Controller (ACC).
| void ACC_Configure | ( | Acc * | pAcc, |
| uint8_t | idAcc, | ||
| uint8_t | ucSelplus, | ||
| uint8_t | ucSelminus, | ||
| uint16_t | wAc_en, | ||
| uint16_t | wEdge, | ||
| uint16_t | wInvert | ||
| pAcc | Pointer to an Acc instance. |
| idAcc | ACC identifier |
| ucSelplus | input connected to inp, 0~7 |
| ucSelminus | input connected to inm,0~7 |
| wAc_en | Analog comparator enabled/disabled |
| wEdge | CF flag triggering mode |
| wInvert | INVert comparator output,use pattern defined in the device header file |
| uint32_t ACC_GetComparisonResult | ( | Acc * | pAcc, |
| uint32_t | dwStatus | ||
Return Comparison Result
| dwStatus | value of ACC_ISR |
1.8.15
