RFS Inode Handle. More...
#include <rtems-rfs-inode.h>
Data Fields | |
| rtems_chain_node | link |
| Handles can be linked as a list for easy processing. | |
| rtems_rfs_ino | ino |
| The ino for this handle. | |
| rtems_rfs_inode * | node |
| The pointer to the inode. | |
| rtems_rfs_buffer_handle | buffer |
| The buffer that contains this inode. | |
| rtems_rfs_buffer_block | block |
| The block number that holds the inode. | |
| int | offset |
| The offset into the block for the inode. | |
| int | loads |
| Number of load requests. | |
RFS Inode Handle.
