libmisc
serdbg
serdbg.h
1
2
| Project: RTEMS remote gdb over serial line |
3
4
| File: serdbg.h |
5
6
| Copyright (c) 2002 IMD |
7
| Ingenieurbuero fuer Microcomputertechnik Th. Doerfler |
8
| <Thomas.Doerfler@imd-systems.de> |
9
| all rights reserved |
10
11
| this file declares intialization functions to add |
12
| a gdb remote debug stub to an RTEMS system |
13
14
15
| date history ID |
16
17
| 04.04.02 creation doe |
18
19
#ifndef _SERDBG_H
20
#define _SERDBG_H
21
22
rtems.h
23
termios.h
24
25
#ifdef __cplusplus
26
extern
"C"
27
#endif
28
29
typedef
struct
30
uint32_t baudrate;
/* debug baud rate, e.g. 57600 */
31
void (*
callout
)(void);
/* callout pointer during polling */
32
int (*open_io)(
const
char
*dev_name, uint32_t baudrate);
/* I/O open fnc */
33
const
char
*devname;
/* debug device, e.g. "/dev/tty01" */
34
bool
skip_init_bkpt;
/* if TRUE, do not stop when initializing */
35
serdbg_conf_t
36
37
38
* must be defined in init module...
39
40
extern
serdbg_conf_t
serdbg_conf;
41
42
43
44
| Function: |
45
46
void
putDebugChar
47
48
49
| Purpose: |
50
| send character to remote debugger |
51
52
| Input Parameters: |
53
54
char
/* char to send */
55
56
57
| Return Value: |
58
| <none> |
59
60
61
62
| Function: |
63
64
int
getDebugChar
65
66
67
| Purpose: |
68
| get character from remote debugger |
69
70
| Input Parameters: |
71
72
void
/* <none> */
73
74
75
| Return Value: |
76
| <none> |
77
78
79
80
| Function: |
81
82
void
serdbg_exceptionHandler
83
84
85
| Purpose: |
86
| hook directly to an exception vector |
87
88
| Input Parameters: |
89
90
int
vecnum,
/* vector index to hook at */
91
void
*vector
/* address of handler function */
92
93
94
| Return Value: |
95
| <none> |
96
97
98
99
| Function: |
100
101
int
serdbg_init
102
103
104
| Purpose: |
105
| initialize remote gdb session over serial line |
106
107
| Input Parameters: |
108
109
void
110
111
112
| Return Value: |
113
| rtems_status_code |
114
115
116
117
* stuff from serdbgio.c
118
119
120
| Function: |
121
122
int
serdbg_open
123
124
125
| Purpose: |
126
| try to open given serial debug port |
127
128
| Input Parameters: |
129
130
131
const
char
*dev_name,
/* name of device to open */
132
uint32_t baudrate
/* baud rate to use */
133
134
135
| Return Value: |
136
| 0 on success, -1 and errno otherwise |
137
138
139
140
extern
int
serdbg_init_dbg(
void
141
142
143
* Assumed to be provided by the BSP
144
145
extern
void
set_debug_traps(
void
146
extern
void
breakpoint(
void
147
#ifdef __cplusplus
148
149
#endif
150
151
#endif
/* _SERDBG_H */
termios.h
POSIX Termios Implementation for RTEMS Console Device Driver.
rtems.h
serdbg_conf_t
Definition:
serdbg.h:30
callout
Definition:
callout.h:42
