#include <rtems/config.h>
#include <rtems/debug.h>
#include <rtems/init.h>
#include <rtems/rtems/options.h>
#include <rtems/rtems/intr.h>
#include <rtems/rtems/barrier.h>
#include <rtems/rtems/cache.h>
#include <rtems/rtems/clock.h>
#include <rtems/extension.h>
#include <rtems/rtems/timer.h>
#include <rtems/rtems/sem.h>
#include <rtems/rtems/message.h>
#include <rtems/rtems/event.h>
#include <rtems/rtems/signal.h>
#include <rtems/rtems/object.h>
#include <rtems/rtems/part.h>
#include <rtems/rtems/region.h>
#include <rtems/rtems/dpmem.h>
#include <rtems/io.h>
#include <rtems/fatal.h>
#include <rtems/rtems/ratemon.h>
#include <rtems/rtems/smp.h>
#define | RTEMS_HAS_HARDWARE_FP CPU_HARDWARE_FP |
Indicates whether this processor variant has hardware floating point support. | |
#define | RTEMS_SEARCH_ALL_NODES OBJECTS_SEARCH_ALL_NODES |
Indicates that a search is across all nodes. | |
#define | RTEMS_SEARCH_OTHER_NODES OBJECTS_SEARCH_OTHER_NODES |
Indicates that a search is across all nodes except the one the call is made from. | |
#define | RTEMS_SEARCH_LOCAL_NODE OBJECTS_SEARCH_LOCAL_NODE |
Indicates that the search is to be restricted to the local node. | |
#define | RTEMS_WHO_AM_I OBJECTS_WHO_AM_I |
Indicates that the caller wants to obtain the name of the currently executing thread. More... | |
#define | RTEMS_OBJECT_ID_INITIAL_INDEX OBJECTS_ID_INITIAL_INDEX |
Lowest valid index value for the index portion of an object identifier. | |
#define | RTEMS_OBJECT_ID_FINAL_INDEX OBJECTS_ID_FINAL_INDEX |
Maximum valid index value for the index portion of an object identifier. | |
#define | RTEMS_OBJECT_ID_INITIAL(_api, _class, _node) OBJECTS_ID_INITIAL(_api, _class, _node) |
Returns the identifier of the object with the lowest valid index value. More... | |
#define | RTEMS_OBJECT_ID_FINAL OBJECTS_ID_FINAL |
Maximum valid object identifier. | |
#define | RTEMS_MINIMUM_STACK_SIZE STACK_MINIMUM_SIZE |
Minimum stack size which every thread must exceed. More... | |
#define | RTEMS_CONFIGURED_MINIMUM_STACK_SIZE 0 |
Specifies that the task should be created with the configured minimum stack size. More... | |
#define | RTEMS_NO_TIMEOUT WATCHDOG_NO_TIMEOUT |
Constant for indefinite wait. More... | |
#define | RTEMS_MINIMUM_PACKET_SIZE MP_PACKET_MINIMUM_PACKET_SIZE |
An MPCI must support packets of at least this size. | |
#define | RTEMS_MINIMUN_HETERO_CONVERSION MP_PACKET_MINIMUN_HETERO_CONVERSION |
Defines the count of uint32_t numbers in a packet which must be converted to native format in a heterogeneous system. More... | |
const char * | rtems_get_version_string (void) |
Returns the pointer to the RTEMS version string. | |
