#define | RTEMS_RFS_TRACE 1 |
| Is tracing enabled ?
#define | RTEMS_RFS_TRACE_ALL (0xffffffffffffffffULL) |
| List of tracing bits for the various parts of the file system.
#define | RTEMS_RFS_TRACE_OPEN (1ULL << 0) |
#define | RTEMS_RFS_TRACE_CLOSE (1ULL << 1) |
#define | RTEMS_RFS_TRACE_MUTEX (1ULL << 2) |
#define | RTEMS_RFS_TRACE_BUFFER_OPEN (1ULL << 3) |
#define | RTEMS_RFS_TRACE_BUFFER_CLOSE (1ULL << 4) |
#define | RTEMS_RFS_TRACE_BUFFER_SYNC (1ULL << 5) |
#define | RTEMS_RFS_TRACE_BUFFER_RELEASE (1ULL << 6) |
#define | RTEMS_RFS_TRACE_BUFFER_CHAINS (1ULL << 7) |
#define | RTEMS_RFS_TRACE_BUFFER_HANDLE_REQUEST (1ULL << 8) |
#define | RTEMS_RFS_TRACE_BUFFER_HANDLE_RELEASE (1ULL << 9) |
#define | RTEMS_RFS_TRACE_BUFFER_SETBLKSIZE (1ULL << 10) |
#define | RTEMS_RFS_TRACE_BUFFERS_RELEASE (1ULL << 11) |
#define | RTEMS_RFS_TRACE_BLOCK_FIND (1ULL << 12) |
#define | RTEMS_RFS_TRACE_BLOCK_MAP_GROW (1ULL << 13) |
#define | RTEMS_RFS_TRACE_BLOCK_MAP_SHRINK (1ULL << 14) |
#define | RTEMS_RFS_TRACE_GROUP_OPEN (1ULL << 15) |
#define | RTEMS_RFS_TRACE_GROUP_CLOSE (1ULL << 16) |
#define | RTEMS_RFS_TRACE_GROUP_BITMAPS (1ULL << 17) |
#define | RTEMS_RFS_TRACE_INODE_OPEN (1ULL << 18) |
#define | RTEMS_RFS_TRACE_INODE_CLOSE (1ULL << 19) |
#define | RTEMS_RFS_TRACE_INODE_LOAD (1ULL << 20) |
#define | RTEMS_RFS_TRACE_INODE_UNLOAD (1ULL << 21) |
#define | RTEMS_RFS_TRACE_INODE_CREATE (1ULL << 22) |
#define | RTEMS_RFS_TRACE_INODE_DELETE (1ULL << 23) |
#define | RTEMS_RFS_TRACE_LINK (1ULL << 24) |
#define | RTEMS_RFS_TRACE_UNLINK (1ULL << 25) |
#define | RTEMS_RFS_TRACE_DIR_LOOKUP_INO (1ULL << 26) |
#define | RTEMS_RFS_TRACE_DIR_LOOKUP_INO_CHECK (1ULL << 27) |
#define | RTEMS_RFS_TRACE_DIR_LOOKUP_INO_FOUND (1ULL << 28) |
#define | RTEMS_RFS_TRACE_DIR_ADD_ENTRY (1ULL << 29) |
#define | RTEMS_RFS_TRACE_DIR_DEL_ENTRY (1ULL << 30) |
#define | RTEMS_RFS_TRACE_DIR_READ (1ULL << 31) |
#define | RTEMS_RFS_TRACE_DIR_EMPTY (1ULL << 32) |
#define | RTEMS_RFS_TRACE_SYMLINK (1ULL << 33) |
#define | RTEMS_RFS_TRACE_SYMLINK_READ (1ULL << 34) |
#define | RTEMS_RFS_TRACE_FILE_OPEN (1ULL << 35) |
#define | RTEMS_RFS_TRACE_FILE_CLOSE (1ULL << 36) |
#define | RTEMS_RFS_TRACE_FILE_IO (1ULL << 37) |
#define | RTEMS_RFS_TRACE_FILE_SET (1ULL << 38) |
Manages the Trace and Debugging Features of the RTEMS RFS File System.
RTEMS File Systems Trace manages the trace and debugging features of the RTEMS RFS file system. The design allows all tracing code and strings to be removed from the target code for small footprint systems.
