Files | |
file | bdbuf.c |
Block device buffer management. | |
file | bdpart-create.c |
Manage Partitions of a Disk Device. | |
file | bdpart-dump.c |
Prints the Partition Table Partitions with Count Partitions. | |
file | bdpart-mount.c |
Block Device Partition Management. | |
file | bdpart-read.c |
file | bdpart-register.c |
file | bdpart-sort.c |
file | bdpart-write.c |
file | blkdev-blkstats.c |
Block Device Statistics Command. | |
file | blkdev-imfs.c |
Block Device IMFS. | |
file | blkdev-ioctl.c |
Common IO Control Primitive. | |
file | blkdev-ops.c |
Block device management. | |
file | blkdev-print-stats.c |
Prints the Block Device Statistics. | |
file | blkdev.c |
Block Device Management. | |
file | diskdevs-init.c |
Block Device Disk Management Initialize. | |
file | diskdevs.c |
Block device disk management implementation. | |
file | flashdisk.c |
Flash Disk Block Device Implementation. | |
file | ide_part_table.c |
Library supporting "MS-DOS-style" Partition Table. | |
file | media-desc.c |
Media implementation. | |
file | media-dev-ident.c |
file | media-path.c |
file | media-server.c |
file | media.c |
file | nvdisk-sram.c |
Provide SRAM support for the NV Disk. | |
file | nvdisk.c |
Non-Volatile Disk Block Device Implementation. | |
file | ramdisk-config.c |
RAM disk block device implementation. | |
file | ramdisk-driver.c |
file | ramdisk-init.c |
file | ramdisk-register.c |
file | show_bdbuf.c |
Enable the Monitor to Show bdbuf InformationThis module inspects the bdbuf data structures, assuming they are static, but in fact they are used very dynamically. | |
file | sparse-disk.c |
Sparse disk block device implementation. | |
