Files | |
file | dosfs.h [code] |
Application Interface to FAT Filesystem. | |
file | fat.c |
Low-level Operations on a Volume with a DOSFS FAT filesystem. | |
file | fat.h [code] |
Constants/Data Structures/Prototypes on a Volume with FAT Filesystem. | |
file | fat_fat_operations.c |
General operations on File Allocation Table. | |
file | fat_fat_operations.h [code] |
Constants/Data Structures/Prototypes for Files Allocation Table. | |
file | fat_file.c |
General operations on "fat-file". | |
file | fat_file.h [code] |
Constants/Data Structures/Prototypes for Operations on "fat-file". | |
file | msdos.h [code] |
The MSDOS Filesystem Constants/Data Structures/Prototypes. | |
file | msdos_conv.c |
MDOS Date Conversion. | |
file | msdos_conv_default.c |
Default Converter. | |
file | msdos_conv_utf8.c |
UTF-8 Converter. | |
file | msdos_create.c |
Create a new MSDOS FileSystem node. | |
file | msdos_dir.c |
MSDOS Directory Handlers Implementation. | |
file | msdos_eval.c |
MSDOS Evaluation Routines. | |
file | msdos_file.c |
MSDOS File Handlers Implementation. | |
file | msdos_format.c |
RTEMS MSDOS Format FunctionalityThis function formats a disk partition conforming to MS-DOS conventions. | |
file | msdos_free.c |
Call Fat-File Close Routine. | |
file | msdos_fsunmount.c |
Shut Down MSDOS FileSystem. | |
file | msdos_handlers_dir.c |
Directory Handlers Table for MSDOS FileSystem. | |
file | msdos_handlers_file.c |
File Operations Table for MSDOS FileSystem. | |
file | msdos_init.c |
Init Routine for MSDOS. | |
file | msdos_initsupp.c |
MSDOS Filesystem Initialization. | |
file | msdos_misc.c |
Miscellaneous Routines Implementation for MSDOS FileSystem. | |
file | msdos_mknod.c |
Routine for Node Creation in MSDOS Filesystem. | |
file | msdos_rename.c |
Rename a MSDOS FileSystem Node. | |
file | msdos_rmnod.c |
Remove Node from MSDOS Directory. | |
file | msdos_statvfs.c |
Obtain MS-DOS filesystem information. | |
