#define | re_errno ru.RE_errno |
#define | re_why ru.RE_why |
#define | re_vers ru.RE_vers |
#define | re_lb ru.RE_lb |
#define | RPCSMALLMSGSIZE 400 /* a more reasonable packet size */ |
#define | CLNT_CALL(rh, proc, xargs, argsp, xres, resp, secs) |
#define | clnt_call(rh, proc, xargs, argsp, xres, resp, secs) |
#define | CLNT_ABORT(rh) ((*(rh)->cl_ops->cl_abort)(rh)) |
#define | clnt_abort(rh) ((*(rh)->cl_ops->cl_abort)(rh)) |
#define | CLNT_GETERR(rh, errp) ((*(rh)->cl_ops->cl_geterr)(rh, errp)) |
#define | clnt_geterr(rh, errp) ((*(rh)->cl_ops->cl_geterr)(rh, errp)) |
#define | CLNT_FREERES(rh, xres, resp) ((*(rh)->cl_ops->cl_freeres)(rh,xres,resp)) |
#define | clnt_freeres(rh, xres, resp) ((*(rh)->cl_ops->cl_freeres)(rh,xres,resp)) |
#define | CLNT_CONTROL(cl, rq, in) ((*(cl)->cl_ops->cl_control)(cl,rq,in)) |
#define | clnt_control(cl, rq, in) ((*(cl)->cl_ops->cl_control)(cl,rq,in)) |
#define | CLSET_TIMEOUT 1 /* set timeout (timeval) */ |
#define | CLGET_TIMEOUT 2 /* get timeout (timeval) */ |
#define | CLGET_SERVER_ADDR 3 /* get server's address (sockaddr) */ |
#define | CLGET_FD 6 /* get connections file descriptor */ |
#define | CLGET_SVC_ADDR 7 /* get server's address (netbuf) */ |
#define | CLSET_FD_CLOSE 8 /* close fd while clnt_destroy */ |
#define | CLSET_FD_NCLOSE 9 /* Do not close fd while clnt_destroy */ |
#define | CLGET_XID 10 /* Get xid */ |
#define | CLSET_XID 11 /* Set xid */ |
#define | CLGET_VERS 12 /* Get version number */ |
#define | CLSET_VERS 13 /* Set version number */ |
#define | CLGET_PROG 14 /* Get program number */ |
#define | CLSET_PROG 15 /* Set program number */ |
#define | CLSET_SVC_ADDR 16 /* get server's address (netbuf) XXX */ |
#define | CLSET_PUSH_TIMOD 17 /* push timod if not already present XXX */ |
#define | CLSET_POP_TIMOD 18 /* pop timod XXX */ |
#define | CLSET_RETRY_TIMEOUT 4 /* set retry timeout (timeval) */ |
#define | CLGET_RETRY_TIMEOUT 5 /* get retry timeout (timeval) */ |
#define | CLGET_LOCAL_ADDR 19 /* get local addr (sockaddr) */ |
#define | CLNT_DESTROY(rh) ((*(rh)->cl_ops->cl_destroy)(rh)) |
#define | clnt_destroy(rh) ((*(rh)->cl_ops->cl_destroy)(rh)) |
#define | RPCTEST_PROGRAM ((rpcprog_t)1) |
#define | RPCTEST_VERSION ((rpcvers_t)1) |
#define | RPCTEST_NULL_PROC ((rpcproc_t)2) |
#define | RPCTEST_NULL_BATCH_PROC ((rpcproc_t)3) |
#define | NULLPROC ((rpcproc_t)0) |
__BEGIN_DECLS CLIENT * | clnt_create (const char *, const rpcprog_t, const rpcvers_t, const char *) |
__END_DECLS __BEGIN_DECLS CLIENT * | clntunix_create (struct sockaddr_un *, u_long, u_long, int *, u_int, u_int) |
__END_DECLS __BEGIN_DECLS void | clnt_pcreateerror (const char *) |
char * | clnt_spcreateerror (const char *) |
__END_DECLS __BEGIN_DECLS void | clnt_perrno (enum clnt_stat) |
char * | clnt_sperrno (enum clnt_stat) |
__END_DECLS __BEGIN_DECLS void | clnt_perror (CLIENT *, const char *) |
char * | clnt_sperror (CLIENT *, const char *) |
