libnetworking
sys
un.h
1
2
* Copyright (c) 1982, 1986, 1993
3
* The Regents of the University of California. All rights reserved.
4
5
6
* modification, are permitted provided that the following conditions
7
* are met:
8
* 1. Redistributions of source code must retain the above copyright
9
* notice, this list of conditions and the following disclaimer.
10
* 2. Redistributions in binary form must reproduce the above copyright
11
* notice, this list of conditions and the following disclaimer in the
12
* documentation and/or other materials provided with the distribution.
13
* 4. Neither the name of the University nor the names of its contributors
14
* may be used to endorse or promote products derived from this software
15
* without specific prior written permission.
16
17
* THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
18
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
19
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
20
* ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
21
* FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
22
* DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
23
* OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
24
* HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
25
* LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
26
* OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
27
* SUCH DAMAGE.
28
29
* @(#)un.h 8.3 (Berkeley) 2/19/95
30
* $FreeBSD: src/sys/sys/un.h,v 1.29 2005/04/13 00:01:46 mdodd Exp $
31
32
33
34
#ifndef _SYS_UN_H_
35
#define _SYS_UN_H_
36
37
#include <sys/cdefs.h>
38
rtems/bsdnet/_types.h
39
40
#ifndef _SA_FAMILY_T_DECLARED
41
typedef
__sa_family_t sa_family_t;
42
#define _SA_FAMILY_T_DECLARED
43
#endif
44
45
46
* Definitions for UNIX IPC domain.
47
48
struct
sockaddr_un
49
unsigned
char
sun_len;
/* sockaddr len including null */
50
sa_family_t sun_family;
/* AF_UNIX */
51
char
sun_path[104];
/* path name (gag) */
52
53
54
#if __BSD_VISIBLE
55
56
/* Socket options. */
57
#define LOCAL_PEERCRED 0x001
/* retrieve peer credentials */
58
#define LOCAL_CREDS 0x002
/* pass credentials to receiver */
59
#define LOCAL_CONNWAIT 0x004
/* connects block until accepted */
60
61
#ifdef _KERNEL
62
struct
mbuf
63
struct
socket
64
struct
sockopt;
65
66
#else
/* !_KERNEL */
67
68
/* actual length of an initialized sockaddr_un */
69
#define SUN_LEN(su) \
70
(sizeof(*(su)) - sizeof((su)->sun_path) + strlen((su)->sun_path))
71
72
#endif
/* _KERNEL */
73
74
#endif
/* __BSD_VISIBLE */
75
76
#endif
/* !_SYS_UN_H_ */
socket
Definition:
socketvar.h:49
sockaddr_un
Definition:
un.h:49
mbuf
Definition:
mbuf.h:103
_types.h
