rtems_bdpart_format Union Reference
Disk format description. More...
#include <bdpart.h>
rtems_bdpart_format_type type
 Format type.
struct {
   uint32_t   disk_id
 Disk ID in MBR at offset 440.
   bool   dos_compatibility
 This option is used for partition table creation and validation checks before a write to the disk. More...
} mbr
 MBR format fields.
struct {
   uuid_t   disk_id
 Disk ID in GPT header.
} gpt
 GPT format fields.
Field Documentation
◆ dos_compatibility
bool rtems_bdpart_format::dos_compatibility
It ensures that the first primary partition and the logical partitions start at head one and sector one under the virtual one head and 63 sectors geometry. Each begin and end of a partition will be aligned to the virtual cylinder boundary.
Referenced by rtems_bdpart_create(), and rtems_bdpart_write().
The documentation for this union was generated from the following file:
