Macros | Typedefs | Functions | Variables
threadimpl.h File Reference
Inlined Routines from the Thread Handler. More...
#include <rtems/score/interr.h>
#include <rtems/score/isr.h>
#include <rtems/score/resourceimpl.h>
#include <rtems/score/sysstate.h>
#include <rtems/config.h>
Include dependency graph for threadimpl.h:
#define THREAD_STATUS_PROXY_BLOCKING   0x1111111
 The following structure contains the information necessary to manage a thread which it is waiting for a resource.
#define THREAD_CHAIN_NODE_TO_THREAD(node)   RTEMS_CONTAINER_OF( node, Thread_Control, Wait.Node.Chain )
#define THREAD_RBTREE_NODE_TO_THREAD(node)   RTEMS_CONTAINER_OF( node, Thread_Control, Wait.Node.RBTree )
#define _Thread_Lock_set(the_thread, new_lock)   do { } while ( 0 )
 Sets a new thread lock. More...
#define _Thread_Lock_restore_default(the_thread)   do { } while ( 0 )
 Restores the default thread lock. More...
#define THREAD_WAIT_FLAGS_INITIAL   0x0U
 The initial thread wait flags value set by _Thread_Initialize().
#define THREAD_WAIT_STATE_MASK   0xffU
 Mask to get the thread wait state flags.
#define THREAD_WAIT_STATE_INTEND_TO_BLOCK   0x1U
 Indicates that the thread begins with the blocking operation. More...
#define THREAD_WAIT_STATE_BLOCKED   0x2U
 Indicates that the thread completed the blocking operation.
#define THREAD_WAIT_STATE_READY_AGAIN   0x4U
 Indicates that a condition to end the thread wait occurred. More...
#define THREAD_WAIT_CLASS_MASK   0xff00U
 Mask to get the thread wait class flags.
#define THREAD_WAIT_CLASS_EVENT   0x100U
 Indicates that the thread waits for an event.
#define THREAD_WAIT_CLASS_SYSTEM_EVENT   0x200U
 Indicates that the thread waits for a system event.
#define THREAD_WAIT_CLASS_OBJECT   0x400U
 Indicates that the thread waits for a object.
typedef bool(* Thread_Change_priority_filter) (Thread_Control *the_thread, Priority_Control *new_priority, void *arg)
 Filters a thread priority change. More...
void _Thread_Handler_initialization (void)
 Initialize thread handler. More...
void _Thread_Create_idle (void)
 Create idle thread. More...
void _Thread_Start_multitasking (void)
 Start thread multitasking. More...
size_t _Thread_Stack_Allocate (Thread_Control *the_thread, size_t stack_size)
 Allocate the requested stack space for the thread. More...
void _Thread_Stack_Free (Thread_Control *the_thread)
 Deallocate thread stack. More...
bool _Thread_Initialize (Objects_Information *information, Thread_Control *the_thread, const struct Scheduler_Control *scheduler, void *stack_area, size_t stack_size, bool is_fp, Priority_Control priority, bool is_preemptible, Thread_CPU_budget_algorithms budget_algorithm, Thread_CPU_budget_algorithm_callout budget_callout, uint32_t isr_level, Objects_Name name)
 Initialize thread. More...
bool _Thread_Start (Thread_Control *the_thread, Thread_Start_types the_prototype, void *entry_point, void *pointer_argument, Thread_Entry_numeric_type numeric_argument, Per_CPU_Control *cpu)
 Initializes thread and executes it. More...
bool _Thread_Restart (Thread_Control *the_thread, Thread_Control *executing, void *pointer_argument, Thread_Entry_numeric_type numeric_argument)
void _Thread_Yield (Thread_Control *executing)
bool _Thread_Set_life_protection (bool protect)
void _Thread_Life_action_handler (Thread_Control *executing, Thread_Action *action, Per_CPU_Control *cpu, ISR_Level level)
void _Thread_Kill_zombies (void)
 Kills all zombie threads in the system. More...
void _Thread_Close (Thread_Control *the_thread, Thread_Control *executing)
 Closes the thread. More...
States_Control _Thread_Clear_state (Thread_Control *the_thread, States_Control state)
 Clears the specified thread state. More...
States_Control _Thread_Set_state (Thread_Control *the_thread, States_Control state)
 Sets the specified thread state. More...
RTEMS_INLINE_ROUTINE void _Thread_Ready (Thread_Control *the_thread)
 Clears all thread states. More...
void _Thread_Load_environment (Thread_Control *the_thread)
 Initializes enviroment for a thread. More...
void _Thread_Handler (void)
 Wrapper function for all threads. More...
void * _Thread_Global_construction (void)
 Executes the global constructors and then restarts itself as the first initialization thread. More...
void _Thread_Delay_ended (Objects_Id id, void *ignored)
 Ended the delay of a thread. More...
RTEMS_INLINE_ROUTINE bool _Thread_Priority_less_than (Priority_Control left, Priority_Control right)
 Returns true if the left thread priority is less than the right thread priority in the intuitive sense of priority and false otherwise.
RTEMS_INLINE_ROUTINE Priority_Control _Thread_Priority_highest (Priority_Control left, Priority_Control right)
 Returns the highest priority of the left and right thread priorities in the intuitive sense of priority.
void _Thread_Change_priority (Thread_Control *the_thread, Priority_Control new_priority, void *arg, Thread_Change_priority_filter filter, bool prepend_it)
 Changes the priority of a thread if allowed by the filter function. More...
void _Thread_Raise_priority (Thread_Control *the_thread, Priority_Control new_priority)
 Raises the priority of a thread. More...
void _Thread_Restore_priority (Thread_Control *the_thread)
 Sets the current to the real priority of a thread. More...
void _Thread_Set_priority (Thread_Control *the_thread, Priority_Control new_priority, Priority_Control *old_priority, bool prepend_it)
 Sets the priority of a thread. More...
Thread_Control * _Thread_Get (Objects_Id id, Objects_Locations *location)
 Maps thread Id to a TCB pointer. More...
Thread_Control * _Thread_Get_interrupt_disable (Objects_Id id, Objects_Locations *location, ISR_lock_Context *lock_context)
 Gets a thread by its identifier. More...
RTEMS_INLINE_ROUTINE Per_CPU_Control * _Thread_Get_CPU (const Thread_Control *thread)
RTEMS_INLINE_ROUTINE void _Thread_Set_CPU (Thread_Control *thread, Per_CPU_Control *cpu)
RTEMS_INLINE_ROUTINE bool _Thread_Is_executing (const Thread_Control *the_thread)
 This function returns true if the_thread is the currently executing thread, and false otherwise.
RTEMS_INLINE_ROUTINE bool _Thread_Get_time_of_last_context_switch (Thread_Control *the_thread, Timestamp_Control *time_of_context_switch)
 Returns true and sets time_of_context_switch to the time of the last context switch when the thread is currently executing in the system, otherwise false.
RTEMS_INLINE_ROUTINE bool _Thread_Is_heir (const Thread_Control *the_thread)
 This function returns true if the_thread is the heir thread, and false otherwise.
RTEMS_INLINE_ROUTINE void _Thread_Unblock (Thread_Control *the_thread)
 This routine clears any blocking state for the_thread. More...
RTEMS_INLINE_ROUTINE void _Thread_Restart_self (Thread_Control *executing)
 This routine resets the current context of the calling thread to that of its initial state.
RTEMS_INLINE_ROUTINE bool _Thread_Is_allocated_fp (const Thread_Control *the_thread)
 This function returns true if the floating point context of the_thread is currently loaded in the floating point unit, and false otherwise.
RTEMS_INLINE_ROUTINE void _Thread_Save_fp (Thread_Control *executing)
RTEMS_INLINE_ROUTINE void _Thread_Restore_fp (Thread_Control *executing)
RTEMS_INLINE_ROUTINE void _Thread_Deallocate_fp (void)
 This routine is invoked when the currently loaded floating point context is now longer associated with an active thread.
RTEMS_INLINE_ROUTINE bool _Thread_Is_context_switch_necessary (void)
 This function returns true if dispatching is disabled, and false otherwise.
RTEMS_INLINE_ROUTINE bool _Thread_Is_null (const Thread_Control *the_thread)
 This function returns true if the_thread is NULL and false otherwise.
RTEMS_INLINE_ROUTINE bool _Thread_Is_proxy_blocking (uint32_t code)
 Is proxy blocking. More...
RTEMS_INLINE_ROUTINE uint32_t _Thread_Get_maximum_internal_threads (void)
RTEMS_INLINE_ROUTINE Thread_Control * _Thread_Internal_allocate (void)
RTEMS_INLINE_ROUTINE Thread_Control * _Thread_Get_heir_and_make_it_executing (Per_CPU_Control *cpu_self)
 Gets the heir of the processor and makes it executing. More...
RTEMS_INLINE_ROUTINE void _Thread_Update_cpu_time_used (Thread_Control *executing, Timestamp_Control *time_of_last_context_switch)
RTEMS_INLINE_ROUTINE void _Thread_Action_control_initialize (Thread_Action_control *action_control)
RTEMS_INLINE_ROUTINE void _Thread_Action_initialize (Thread_Action *action, Thread_Action_handler handler)
RTEMS_INLINE_ROUTINE Per_CPU_Control * _Thread_Action_ISR_disable_and_acquire_for_executing (ISR_Level *level)
RTEMS_INLINE_ROUTINE Per_CPU_Control * _Thread_Action_ISR_disable_and_acquire (Thread_Control *thread, ISR_Level *level)
RTEMS_INLINE_ROUTINE void _Thread_Action_release_and_ISR_enable (Per_CPU_Control *cpu, ISR_Level level)
RTEMS_INLINE_ROUTINE void _Thread_Add_post_switch_action (Thread_Control *thread, Thread_Action *action)
RTEMS_INLINE_ROUTINE bool _Thread_Is_life_restarting (Thread_Life_state life_state)
RTEMS_INLINE_ROUTINE bool _Thread_Is_life_terminating (Thread_Life_state life_state)
RTEMS_INLINE_ROUTINE bool _Thread_Is_life_protected (Thread_Life_state life_state)
RTEMS_INLINE_ROUTINE bool _Thread_Is_life_changing (Thread_Life_state life_state)
RTEMS_INLINE_ROUTINE bool _Thread_Owns_resources (const Thread_Control *the_thread)
 Returns true if the thread owns resources, and false otherwise. More...
RTEMS_INLINE_ROUTINE Thread_Control * _Thread_Lock_acquire_default_for_executing (ISR_lock_Context *lock_context)
 Acquires the default thread lock and returns the executing thread. More...
RTEMS_INLINE_ROUTINE void _Thread_Lock_acquire_default_critical (Thread_Control *the_thread, ISR_lock_Context *lock_context)
 Acquires the default thread lock inside a critical section (interrupts disabled). More...
RTEMS_INLINE_ROUTINE void _Thread_Lock_acquire_default (Thread_Control *the_thread, ISR_lock_Context *lock_context)
 Acquires the default thread lock. More...
RTEMS_INLINE_ROUTINE void _Thread_Lock_release_critical (ISR_lock_Control *lock, ISR_lock_Context *lock_context)
 Releases the thread lock inside a critical section (interrupts disabled). More...
RTEMS_INLINE_ROUTINE void _Thread_Lock_release (ISR_lock_Control *lock, ISR_lock_Context *lock_context)
 Releases the thread lock. More...
RTEMS_INLINE_ROUTINE void _Thread_Lock_release_default_critical (Thread_Control *the_thread, ISR_lock_Context *lock_context)
 Releases the default thread lock inside a critical section (interrupts disabled). More...
RTEMS_INLINE_ROUTINE void _Thread_Lock_release_default (Thread_Control *the_thread, ISR_lock_Context *lock_context)
 Releases the default thread lock. More...
RTEMS_INLINE_ROUTINE ISR_lock_Control * _Thread_Lock_acquire (Thread_Control *the_thread, ISR_lock_Context *lock_context)
 Acquires the thread lock. More...
RTEMS_INLINE_ROUTINE void _Thread_Wait_flags_set (Thread_Control *the_thread, Thread_Wait_flags flags)
RTEMS_INLINE_ROUTINE Thread_Wait_flags _Thread_Wait_flags_get (const Thread_Control *the_thread)
RTEMS_INLINE_ROUTINE bool _Thread_Wait_flags_try_change_critical (Thread_Control *the_thread, Thread_Wait_flags expected_flags, Thread_Wait_flags desired_flags)
 Tries to change the thread wait flags inside a critical section (interrupts disabled). More...
RTEMS_INLINE_ROUTINE bool _Thread_Wait_flags_try_change (Thread_Control *the_thread, Thread_Wait_flags expected_flags, Thread_Wait_flags desired_flags)
 Tries to change the thread wait flags. More...
RTEMS_INLINE_ROUTINE void _Thread_Wait_set_queue (Thread_Control *the_thread, Thread_queue_Control *new_queue)
 Sets the thread queue. More...
RTEMS_INLINE_ROUTINE void _Thread_Wait_set_operations (Thread_Control *the_thread, const Thread_queue_Operations *new_operations)
 Sets the thread queue operations. More...
RTEMS_INLINE_ROUTINE void _Thread_Wait_restore_default_operations (Thread_Control *the_thread)
 Restores the default thread queue operations. More...
RTEMS_INLINE_ROUTINE void _Thread_Wait_set_timeout_code (Thread_Control *the_thread, uint32_t timeout_code)
 Sets the thread wait timeout code. More...
void _Thread_Timeout (Objects_Id id, void *arg)
 General purpose thread wait timeout. More...
RTEMS_INLINE_ROUTINE void _Thread_Debug_set_real_processor (Thread_Control *the_thread, Per_CPU_Control *cpu)
RTEMS_INLINE_ROUTINE struct _reent ** _Thread_Get_libc_reent (void)
 This routine returns the C library re-enterant pointer.
RTEMS_INLINE_ROUTINE void _Thread_Set_libc_reent (struct _reent **libc_reent)
 This routine set the C library re-enterant pointer.
SCORE_EXTERN void * rtems_ada_self
 Self for the GNU Ada Run-Time.
SCORE_EXTERN Objects_Information _Thread_Internal_information
 The following defines the information control block used to manage this class of objects.
SCORE_EXTERN Thread_Control * _Thread_Allocated_fp
 The following points to the thread whose floating point context is currently loaded.
SCORE_EXTERN struct _reent ** _Thread_libc_reent
 The C library re-enter-rant global pointer. More...
This file contains the macro implementation of the inlined routines from the Thread handler.
