Data Structures | Macros | Typedefs | Enumerations | Functions | Variables
termiostypes.h File Reference
RTEMS termios device support internal data structures. More...
#include <rtems/libio.h>
#include <rtems/assoc.h>
#include <rtems/chain.h>
#include <stdint.h>
#include <termios.h>
Include dependency graph for termiostypes.h:
struct  ttywakeup
struct  rtems_termios_rawbuf
struct  rtems_termios_device_context
 Termios device context. More...
struct  rtems_termios_device_handler
 Termios device handler. More...
struct  rtems_termios_device_flow
 Termios device flow control handler. More...
struct  rtems_termios_device_node
 Termios device node for installed devices. More...
struct  rtems_termios_tty
struct  rtems_termios_linesw
#define RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER(name)   { RTEMS_INTERRUPT_LOCK_INITIALIZER( name ) }
 Initializer for static initialization of Termios device contexts. More...
#define TTYDISC   0 /* termios tty line discipline */
#define TABLDISC   3 /* tablet discipline */
#define SLIPDISC   4 /* serial IP discipline */
#define PPPDISC   5 /* PPP discipline */
#define MAXLDISC   8
typedef struct rtems_termios_device_context rtems_termios_device_context
typedef struct rtems_termios_device_node rtems_termios_device_node
typedef struct rtems_termios_tty rtems_termios_tty
typedef uint32_t rtems_termios_baud_t
enum  rtems_termios_device_mode { TERMIOS_POLLED, TERMIOS_IRQ_DRIVEN, TERMIOS_TASK_DRIVEN }
RTEMS_INLINE_ROUTINE void rtems_termios_device_context_initialize (rtems_termios_device_context *context, const char *name)
 Initializes a device context. More...
rtems_status_code rtems_termios_device_install (const char *device_file, rtems_device_major_number major, rtems_device_minor_number minor, const rtems_termios_device_handler *handler, const rtems_termios_device_flow *flow, rtems_termios_device_context *context)
 Installs a Termios device. More...
rtems_status_code rtems_termios_device_remove (const char *device_file, rtems_device_major_number major, rtems_device_minor_number minor)
 Removes a Termios device. More...
rtems_status_code rtems_termios_device_open (rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
 Opens an installed Termios device. More...
rtems_status_code rtems_termios_device_close (void *arg)
 Closes an installed Termios device. More...
RTEMS_INLINE_ROUTINE void * rtems_termios_get_device_context (const rtems_termios_tty *tty)
 Returns the device context of an installed Termios device. More...
RTEMS_INLINE_ROUTINE void rtems_termios_device_lock_acquire (rtems_termios_device_context *context, rtems_interrupt_lock_context *lock_context)
 Acquires the device lock. More...
RTEMS_INLINE_ROUTINE void rtems_termios_device_lock_release (rtems_termios_device_context *context, rtems_interrupt_lock_context *lock_context)
 Releases the device lock. More...
void rtems_termios_set_best_baud (struct termios *term, uint32_t baud)
 Sets the best baud value in the Termios control. More...
void rtems_termios_rxirq_occured (struct rtems_termios_tty *tty)
void rtems_termios_puts (const void *buf, size_t len, struct rtems_termios_tty *tty)
tcflag_t rtems_termios_number_to_baud (rtems_termios_baud_t baud)
 Converts the Integral Baud value baud to the Termios Control Flag Representation. More...
rtems_termios_baud_t rtems_termios_baud_to_number (tcflag_t c_cflag)
 Convert Baud Part of Termios control flags to an integral Baud Value. More...
int rtems_termios_baud_to_index (rtems_termios_baud_t termios_baud)
 Convert Bxxx Constant to Index.
int rtems_termios_set_initial_baud (struct rtems_termios_tty *tty, rtems_termios_baud_t baud)
 Sets the initial baud in the Termios context tty. More...
struct rtems_termios_linesw rtems_termios_linesw []
int rtems_termios_nlinesw
const rtems_assoc_t rtems_termios_baud_table []
 RTEMS Termios Baud Table.
◆ RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER
#define RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER (   name)    { RTEMS_INTERRUPT_LOCK_INITIALIZER( name ) }
Parameters
nameThe name for the interrupt lock. It must be a string. The name is only used if profiling is enabled.
Typedef Documentation
◆ rtems_termios_device_context
◆ rtems_termios_device_node
See also
rtems_termios_device_install().
◆ rtems_termios_baud_to_number()
rtems_termios_baud_t rtems_termios_baud_to_number ( tcflag_t  c_cflag)
There is no need to mask the c_cflag with CBAUD.
Return values
0Invalid baud value or a baud value of B0.
otherIntegral baud value.
◆ rtems_termios_device_close()
rtems_status_code rtems_termios_device_close ( void *  arg)
Return values
RTEMS_SUCCESSFULSuccessful operation.
See also
References rtems_fatal_error_occurred(), RTEMS_NO_TIMEOUT, rtems_semaphore_obtain(), RTEMS_SUCCESSFUL, and RTEMS_WAIT.
◆ rtems_termios_device_context_initialize()
RTEMS_INLINE_ROUTINE void rtems_termios_device_context_initialize ( rtems_termios_device_context *  context,
const char *  name
Parameters
[in]contextThe Termios device context.
[in]nameThe name for the interrupt lock. This name must be a string persistent throughout the life time of this lock. The name is only used if profiling is enabled.
References rtems_interrupt_lock_initialize.
◆ rtems_termios_device_install()
rtems_status_code rtems_termios_device_install ( const char *  device_file,
const rtems_termios_device_handler *  handler,
const rtems_termios_device_flow *  flow,
Parameters
[in]device_fileIf not NULL, then a device file for the specified major and minor number will be created.
[in]majorThe device major number of the corresponding device driver.
[in]minorThe device minor number of the corresponding device driver.
[in]handlerThe device handler. It must be persistent throughout the installed time of the device.
[in]flowThe device flow control handler. The device flow control handler are optional and may be NULL. If present must be persistent throughout the installed time of the device.
[in]contextThe device context. It must be persistent throughout the installed time of the device.
Return values
RTEMS_NO_MEMORYNot enough memory to create a device node.
RTEMS_UNSATISFIEDCreation of the device file failed.
RTEMS_RESOURCE_IN_USEThere exists a device node for this major and minor number pair.
RTEMS_INCORRECT_STATETermios is not initialized.
See also
rtems_termios_device_remove(), rtems_termios_device_open(), rtems_termios_device_close() and rtems_termios_get_device_context().
◆ rtems_termios_device_lock_acquire()
RTEMS_INLINE_ROUTINE void rtems_termios_device_lock_acquire ( rtems_termios_device_context *  context,
rtems_interrupt_lock_context *  lock_context
Parameters
[in]lock_contextThe local interrupt lock context for an acquire and release pair.
References rtems_interrupt_lock_acquire.
◆ rtems_termios_device_lock_release()
RTEMS_INLINE_ROUTINE void rtems_termios_device_lock_release ( rtems_termios_device_context *  context,
Parameters
References rtems_interrupt_lock_release, and rtems_termios_set_best_baud().
◆ rtems_termios_device_open()
rtems_status_code rtems_termios_device_open ( rtems_device_major_number  major,
void *  arg
◆ rtems_termios_device_remove()
rtems_status_code rtems_termios_device_remove ( const char *  device_file,
Parameters
[in]device_fileIf not NULL, then the device file to remove.
Return values
RTEMS_INVALID_IDThere is no device installed with this major and minor number pair.
RTEMS_RESOURCE_IN_USEThis device is currently in use.
RTEMS_UNSATISFIEDRemoval of the device file failed.
See also
References rtems_termios_tty::device_node, RTEMS_INCORRECT_STATE, RTEMS_NO_TIMEOUT, rtems_semaphore_obtain(), RTEMS_SUCCESSFUL, and RTEMS_WAIT.
◆ rtems_termios_get_device_context()
RTEMS_INLINE_ROUTINE void* rtems_termios_get_device_context ( const rtems_termios_tty *  tty)
Parameters
[in]ttyThe Termios control.
References rtems_termios_tty::device_context.
◆ rtems_termios_number_to_baud()
tcflag_t rtems_termios_number_to_baud ( rtems_termios_baud_t  baud)
Return values
B0Invalid baud value or a baud value of 0.
otherBaud constant according to baud.
Referenced by rtems_termios_set_initial_baud().
◆ rtems_termios_set_best_baud()
void rtems_termios_set_best_baud ( struct termios *  term,
uint32_t  baud
The valid Termios baud values are between 0 and 460800. The Termios baud value is chosen which minimizes the difference to the value specified.
Parameters
[in]termThe Termios attributes.
[in]baudThe current baud setting of the device.
References rtems_termios_baud_table.
Referenced by rtems_termios_device_lock_release().
◆ rtems_termios_set_initial_baud()
int rtems_termios_set_initial_baud ( struct rtems_termios_tty *  tty,
Return values
0Successful operation.
-1Invalid baud value.
References rtems_termios_number_to_baud().
