rtems_rtl_obj_cpmp_s Struct Reference
The compressed file. More...
#include <rtl-obj-comp.h>
Collaboration diagram for rtems_rtl_obj_cpmp_s:
Collaboration graph
[legend]
rtems_rtl_obj_cache_t * cache
 The cache provides the input buffer. More...
int fd
 The file descriptor. More...
int compression
 The type of compression. More...
off_t offset
 The base offset of the buffer. More...
size_t size
 The size of the output buffer. More...
size_t level
 The amount of data in the buffer. More...
uint8_t * buffer
 The buffer.
uint32_t read
 The amount of data read. More...
Field Documentation
◆ cache
rtems_rtl_obj_cache_t* rtems_rtl_obj_cpmp_s::cache
Referenced by rtems_rtl_obj_comp_close(), and rtems_rtl_obj_comp_set().
◆ compression
int rtems_rtl_obj_cpmp_s::compression
◆ fd
int rtems_rtl_obj_cpmp_s::fd
◆ level
size_t rtems_rtl_obj_cpmp_s::level
Referenced by rtems_rtl_obj_comp_set().
◆ offset
off_t rtems_rtl_obj_cpmp_s::offset
◆ read
uint32_t rtems_rtl_obj_cpmp_s::read
◆ size
size_t rtems_rtl_obj_cpmp_s::size
