rtems_nvdisk_config Struct Reference
RTEMS Non-Volatile Disk configuration table used to initialise the driver. More...
#include <nvdisk.h>
Collaboration diagram for rtems_nvdisk_config:
Collaboration graph
[legend]
uint32_t block_size
 The block size. More...
uint32_t device_count
 The number of devices. More...
const rtems_nvdisk_device_desc * devices
 The device descriptions. More...
uint32_t flags
 Set of flags to control driver. More...
uint32_t info_level
 Default info level. More...
Field Documentation
◆ block_size
uint32_t rtems_nvdisk_config::block_size
The block size.
◆ device_count
uint32_t rtems_nvdisk_config::device_count
◆ devices
const rtems_nvdisk_device_desc* rtems_nvdisk_config::devices
◆ flags
uint32_t rtems_nvdisk_config::flags
◆ info_level
uint32_t rtems_nvdisk_config::info_level
Default info level.
