Rate_monotonic_Control Struct Reference
The following structure defines the control block used to manage each period. More...
#include <ratemon.h>
Collaboration diagram for Rate_monotonic_Control:
Collaboration graph
[legend]
Objects_Control Object
 This field is the object management portion of a Period instance. More...
Watchdog_Control Timer
 This is the timer used to provide the unblocking mechanism. More...
rtems_rate_monotonic_period_states state
 This field indicates the current state of the period. More...
uint32_t next_length
 This field contains the length of the next period to be executed.
Thread_Control * owner
 This field contains a pointer to the TCB for the thread which owns and uses this period instance.
Thread_CPU_usage_t cpu_usage_period_initiated
 This field contains the cpu usage value of the owning thread when the period was initiated. More...
Rate_monotonic_Period_time_t time_period_initiated
 This field contains the wall time value when the period was initiated. More...
Rate_monotonic_Statistics Statistics
 This field contains the statistics maintained for the period.
Field Documentation
◆ cpu_usage_period_initiated
Thread_CPU_usage_t Rate_monotonic_Control::cpu_usage_period_initiated
It is used to compute the period's statistics.
◆ Object
Objects_Control Rate_monotonic_Control::Object
Referenced by _Rate_monotonic_Free(), and rtems_rate_monotonic_create().
◆ state
rtems_rate_monotonic_period_states Rate_monotonic_Control::state
Referenced by _Rate_monotonic_Is_active(), _Rate_monotonic_Is_expired(), _Rate_monotonic_Is_inactive(), and rtems_rate_monotonic_create().
◆ time_period_initiated
Rate_monotonic_Period_time_t Rate_monotonic_Control::time_period_initiated
◆ Timer
Watchdog_Control Rate_monotonic_Control::Timer
Referenced by rtems_rate_monotonic_create().
