#define | CPU_INLINE_ENABLE_DISPATCH FALSE |
#define | CPU_SIMPLE_VECTORED_INTERRUPTS TRUE |
#define | CPU_HAS_SOFTWARE_INTERRUPT_STACK TRUE |
#define | CPU_HAS_HARDWARE_INTERRUPT_STACK FALSE |
#define | CPU_ALLOCATE_INTERRUPT_STACK FALSE |
#define | CPU_ISR_PASSES_FRAME_POINTER 0 |
#define | CPU_SOFTWARE_FP FALSE |
#define | CPU_HARDWARE_FP FALSE |
#define | CPU_ALL_TASKS_ARE_FP FALSE |
#define | CPU_IDLE_TASK_IS_FP FALSE |
#define | CPU_USE_DEFERRED_FP_SWITCH TRUE |
#define | CPU_PROVIDES_IDLE_THREAD_BODY TRUE |
#define | CPU_STACK_GROWS_UP FALSE |
#define | CPU_STRUCTURE_ALIGNMENT __attribute__ ((aligned(16))) |
#define | CPU_TIMESTAMP_USE_INT64_INLINE TRUE |
#define | CPU_BIG_ENDIAN TRUE |
#define | CPU_LITTLE_ENDIAN FALSE |
#define | CPU_MODES_INTERRUPT_MASK 0x0000000f |
#define | CPU_PER_CPU_CONTROL_SIZE 0 |
#define | _CPU_Context_Get_SP(_context) (_context)->r15 |
#define | CPU_CONTEXT_FP_SIZE sizeof( Context_Control_fp ) |
#define | CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 0 |
#define | CPU_INTERRUPT_NUMBER_OF_VECTORS 256 |
#define | CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER (CPU_INTERRUPT_NUMBER_OF_VECTORS - 1) |
#define | CPU_PROVIDES_ISR_IS_IN_PROGRESS FALSE |
#define | CPU_STACK_MINIMUM_SIZE 4096 |
#define | CPU_SIZEOF_POINTER 4 |
#define | CPU_ALIGNMENT 4 |
#define | CPU_HEAP_ALIGNMENT CPU_ALIGNMENT |
#define | CPU_PARTITION_ALIGNMENT CPU_ALIGNMENT |
#define | CPU_STACK_ALIGNMENT CPU_ALIGNMENT |
#define | _CPU_Initialize_vectors() |
#define | _CPU_ISR_Disable(_level) sh_disable_interrupts( _level ) |
#define | _CPU_ISR_Enable(_level) sh_enable_interrupts( _level) |
#define | _CPU_ISR_Flash(_level) sh_flash_interrupts( _level) |
#define | _CPU_ISR_Set_level(_newlevel) sh_set_interrupt_level(_newlevel) |
#define | _CPU_Context_Restart_self(_the_context) _CPU_Context_restore( (_the_context) ); |
#define | _CPU_Context_Fp_start(_base, _offset) ( (void *) _Addresses_Add_offset( (_base), (_offset) ) ) |
#define | _CPU_Context_Initialize_fp(_destination) { } |
| #define | _CPU_Fatal_halt(_source, _error) |
#define | CPU_USE_GENERIC_BITFIELD_CODE TRUE |
#define | CPU_USE_GENERIC_BITFIELD_DATA TRUE |
| #define | _CPU_Bitfield_Find_first_bit(_value, _output) |
#define | _CPU_Priority_Mask(_bit_number) ( 1 << (_bit_number) ) |
#define | _CPU_Priority_bits_index(_priority) (_priority) |
SCORE_EXTERN void | CPU_delay (uint32_t microseconds) |
| uint32_t | _CPU_ISR_Get_level (void) |
| | Return the current interrupt disable level for this task in the format used by the interrupt level portion of the task mode. More...
SCORE_EXTERN void | _CPU_Context_Initialize (Context_Control *_the_context, void *_stack_base, uint32_t _size, uint32_t _isr, void(*_entry_point)(void), int _is_fp, void *_tls_area) |
| void | _CPU_Initialize (void) |
| | CPU initialization. More...
| void | _CPU_ISR_install_raw_handler (uint32_t vector, proc_ptr new_handler, proc_ptr *old_handler) |
| | This routine installs a "raw" interrupt handler directly into the processor's vector table. More...
| void | _CPU_ISR_install_vector (uint32_t vector, proc_ptr new_handler, proc_ptr *old_handler) |
| | This routine installs an interrupt vector. More...
| void | _CPU_Install_interrupt_stack (void) |
| | This routine installs the hardware interrupt stack pointer. More...
| void * | _CPU_Thread_Idle_body (uintptr_t ignored) |
| | This routine is the CPU dependent IDLE thread body. More...
| void | _CPU_Context_switch (Context_Control *run, Context_Control *heir) |
| | CPU switch context. More...
| void | _CPU_Context_restore (Context_Control *new_context) |
| | This routine is generally used only to restart self in an efficient manner. More...
| void | _CPU_Context_save_fp (Context_Control_fp **fp_context_ptr) |
| | This routine saves the floating point context passed to it. More...
| void | _CPU_Context_restore_fp (Context_Control_fp **fp_context_ptr) |
| | This routine restores the floating point context passed to it. More...
| void | _CPU_Exception_frame_print (const CPU_Exception_frame *frame) |
| | Prints the exception frame via printk(). More...
| CPU_Counter_ticks | _CPU_Counter_read (void) |
| | Returns the current CPU counter value. More...
