#define | CPU_INLINE_ENABLE_DISPATCH FALSE |
#define | CPU_PROVIDES_IDLE_THREAD_BODY FALSE |
#define | CPU_STACK_GROWS_UP FALSE |
#define | CPU_STRUCTURE_ALIGNMENT __attribute__ ((aligned (PPC_STRUCTURE_ALIGNMENT))) |
#define | CPU_TIMESTAMP_USE_STRUCT_TIMESPEC TRUE |
#define | CPU_BIG_ENDIAN FALSE |
#define | CPU_LITTLE_ENDIAN TRUE |
#define | CPU_HARDWARE_FP FALSE |
#define | CPU_SOFTWARE_FP FALSE |
#define | CPU_ALL_TASKS_ARE_FP CPU_HARDWARE_FP |
#define | CPU_IDLE_TASK_IS_FP FALSE |
#define | CPU_PER_CPU_CONTROL_SIZE 0 |
#define | PPC_GPR_TYPE uint32_t |
#define | PPC_GPR_SIZE 4 |
#define | PPC_GPR_LOAD lwz |
#define | PPC_GPR_STORE stw |
#define | _CPU_Context_Get_SP(_context) ppc_get_context(_context)->gpr1 |
#define | PPC_CONTEXT_OFFSET_GPR1 (PPC_DEFAULT_CACHE_LINE_SIZE + 0) |
#define | PPC_CONTEXT_OFFSET_MSR (PPC_DEFAULT_CACHE_LINE_SIZE + 4) |
#define | PPC_CONTEXT_OFFSET_LR (PPC_DEFAULT_CACHE_LINE_SIZE + 8) |
#define | PPC_CONTEXT_OFFSET_CR (PPC_DEFAULT_CACHE_LINE_SIZE + 12) |
#define | PPC_CONTEXT_GPR_OFFSET(gpr) (((gpr) - 14) * PPC_GPR_SIZE + PPC_DEFAULT_CACHE_LINE_SIZE + 16) |
#define | PPC_CONTEXT_OFFSET_GPR14 PPC_CONTEXT_GPR_OFFSET( 14 ) |
#define | PPC_CONTEXT_OFFSET_GPR15 PPC_CONTEXT_GPR_OFFSET( 15 ) |
#define | PPC_CONTEXT_OFFSET_GPR16 PPC_CONTEXT_GPR_OFFSET( 16 ) |
#define | PPC_CONTEXT_OFFSET_GPR17 PPC_CONTEXT_GPR_OFFSET( 17 ) |
#define | PPC_CONTEXT_OFFSET_GPR18 PPC_CONTEXT_GPR_OFFSET( 18 ) |
#define | PPC_CONTEXT_OFFSET_GPR19 PPC_CONTEXT_GPR_OFFSET( 19 ) |
#define | PPC_CONTEXT_OFFSET_GPR20 PPC_CONTEXT_GPR_OFFSET( 20 ) |
#define | PPC_CONTEXT_OFFSET_GPR21 PPC_CONTEXT_GPR_OFFSET( 21 ) |
#define | PPC_CONTEXT_OFFSET_GPR22 PPC_CONTEXT_GPR_OFFSET( 22 ) |
#define | PPC_CONTEXT_OFFSET_GPR23 PPC_CONTEXT_GPR_OFFSET( 23 ) |
#define | PPC_CONTEXT_OFFSET_GPR24 PPC_CONTEXT_GPR_OFFSET( 24 ) |
#define | PPC_CONTEXT_OFFSET_GPR25 PPC_CONTEXT_GPR_OFFSET( 25 ) |
#define | PPC_CONTEXT_OFFSET_GPR26 PPC_CONTEXT_GPR_OFFSET( 26 ) |
#define | PPC_CONTEXT_OFFSET_GPR27 PPC_CONTEXT_GPR_OFFSET( 27 ) |
#define | PPC_CONTEXT_OFFSET_GPR28 PPC_CONTEXT_GPR_OFFSET( 28 ) |
#define | PPC_CONTEXT_OFFSET_GPR29 PPC_CONTEXT_GPR_OFFSET( 29 ) |
#define | PPC_CONTEXT_OFFSET_GPR30 PPC_CONTEXT_GPR_OFFSET( 30 ) |
#define | PPC_CONTEXT_OFFSET_GPR31 PPC_CONTEXT_GPR_OFFSET( 31 ) |
#define | PPC_CONTEXT_OFFSET_GPR2 PPC_CONTEXT_GPR_OFFSET( 32 ) |
#define | PPC_CONTEXT_OFFSET_F(f) ( ( ( f ) - 14 ) * 8 + PPC_DEFAULT_CACHE_LINE_SIZE + 96 ) |
#define | PPC_CONTEXT_VOLATILE_SIZE (PPC_CONTEXT_GPR_OFFSET( 32 ) + 4) |
#define | CPU_SIMPLE_VECTORED_INTERRUPTS FALSE |
#define | CPU_HAS_SOFTWARE_INTERRUPT_STACK TRUE |
#define | CPU_HAS_HARDWARE_INTERRUPT_STACK FALSE |
#define | CPU_ALLOCATE_INTERRUPT_STACK TRUE |
#define | CPU_ISR_PASSES_FRAME_POINTER 0 |
#define | CPU_USE_DEFERRED_FP_SWITCH FALSE |
#define | CPU_MODES_INTERRUPT_LEVEL 0x00000001 /* interrupt level in mode */ |
#define | CPU_MODES_INTERRUPT_MASK 0x00000001 /* interrupt level in mode */ |
#define | CPU_CONTEXT_FP_SIZE sizeof( Context_Control_fp ) |
#define | CPU_STACK_CHECK_SIZE (128) |
#define | CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 0 |
#define | CPU_PROVIDES_ISR_IS_IN_PROGRESS FALSE |
#define | _CPU_Fatal_halt(_source, _error) _BSP_Fatal_error(_error) |
#define | CPU_STACK_MINIMUM_SIZE (1024*8) |
#define | CPU_SIZEOF_POINTER 4 |
#define | CPU_ALIGNMENT (PPC_ALIGNMENT) |
#define | CPU_HEAP_ALIGNMENT (PPC_ALIGNMENT) |
#define | CPU_PARTITION_ALIGNMENT (PPC_ALIGNMENT) |
#define | CPU_STACK_ALIGNMENT (PPC_STACK_ALIGNMENT) |
#define | CPU_swap_u16(value) (((value&0xff) << 8) | ((value >> 8)&0xff)) |
#define | _CPU_Context_Restart_self(_the_context) _CPU_Context_restore( (_the_context) ); |
#define | _CPU_Context_Fp_start(_base, _offset) ( (void *) _Addresses_Add_offset( (_base), (_offset) ) ) |
#define | _CPU_Context_Initialize_fp(_destination) memset( *(_destination), 0, sizeof( **(_destination) ) ) |
| #define | _CPU_Bitfield_Find_first_bit(_value, _output) |
#define | _CPU_Priority_Mask(_bit_number) ( 0x80000000 >> (_bit_number) ) |
#define | _CPU_Priority_bits_index(_priority) (_priority) |
void | BSP_panic (char *) |
void | _BSP_Fatal_error (unsigned int) |
| void | _CPU_Context_Initialize (Context_Control *the_context, uint32_t *stack_base, uint32_t size, uint32_t new_level, void *entry_point, bool is_fp, void *tls_area) |
| | Initialize the context to a state suitable for starting a task after a context restore operation. More...
| void | _CPU_Initialize (void) |
| | CPU initialization. More...
| void | _CPU_ISR_install_vector (uint32_t vector, proc_ptr new_handler, proc_ptr *old_handler) |
| | This routine installs an interrupt vector. More...
| void | _CPU_Context_switch (Context_Control *run, Context_Control *heir) |
| | CPU switch context. More...
| void | _CPU_Context_restore (Context_Control *new_context) |
| | This routine is generally used only to restart self in an efficient manner. More...
| void | _CPU_Context_save_fp (Context_Control_fp **fp_context_ptr) |
| | This routine saves the floating point context passed to it. More...
| void | _CPU_Context_restore_fp (Context_Control_fp **fp_context_ptr) |
| | This routine restores the floating point context passed to it. More...
| void | _CPU_Context_volatile_clobber (uintptr_t pattern) |
| | Clobbers all volatile registers with values derived from the pattern parameter. More...
| void | _CPU_Context_validate (uintptr_t pattern) |
| | Initializes and validates the CPU context with values derived from the pattern parameter. More...
| void | _CPU_Exception_frame_print (const CPU_Exception_frame *frame) |
| | Prints the exception frame via printk(). More...
void | _CPU_Initialize_altivec (void) |
void | _CPU_Context_switch_altivec (ppc_context *from, ppc_context *to) |
void | _CPU_Context_restore_altivec (ppc_context *ctxt) |
void | _CPU_Context_initialize_altivec (ppc_context *ctxt) |
void | _CPU_Fatal_error (uint32_t _error) |
PowerPC CPU Department Source.
