Motorola M68K CPU Dependent Source. More...
| struct | Context_Control |
| This defines the minimal set of integer and processor state registers that must be saved during a voluntary context switch from one thread to another. More... | |
| struct | Context_Control_fp |
| This defines the complete set of floating point registers that must be saved during any context switch from one thread to another. More... | |
| struct | CPU_Interrupt_frame |
| This defines the set of integer and processor state registers that must be saved during an interrupt. More... | |
| struct | CPU_Exception_frame |
| The set of registers that specifies the complete processor state. More... | |
| struct | _CPU_ISR_handler_entry |
| #define | CPU_INLINE_ENABLE_DISPATCH TRUE |
| #define | CPU_SIMPLE_VECTORED_INTERRUPTS TRUE |
| #define | CPU_HAS_SOFTWARE_INTERRUPT_STACK 1 |
| #define | CPU_HAS_HARDWARE_INTERRUPT_STACK 0 |
| #define | CPU_ALLOCATE_INTERRUPT_STACK 1 |
| #define | CPU_ISR_PASSES_FRAME_POINTER 0 |
| #define | CPU_HARDWARE_FP FALSE |
| #define | CPU_SOFTWARE_FP FALSE |
| #define | CPU_ALL_TASKS_ARE_FP FALSE |
| #define | CPU_IDLE_TASK_IS_FP FALSE |
| #define | CPU_USE_DEFERRED_FP_SWITCH TRUE |
| #define | CPU_PROVIDES_IDLE_THREAD_BODY TRUE |
| #define | CPU_STACK_GROWS_UP FALSE |
| #define | CPU_STRUCTURE_ALIGNMENT __attribute__ ((aligned (4))) |
| #define | CPU_TIMESTAMP_USE_STRUCT_TIMESPEC TRUE |
| #define | CPU_BIG_ENDIAN TRUE |
| #define | CPU_LITTLE_ENDIAN FALSE |
| #define | CPU_PER_CPU_CONTROL_SIZE 0 |
| #define | M68K_FP_STATE_SIZE 216 |
| #define | _CPU_Context_Get_SP(_context) (_context)->a7_msp |
| #define | _CPU_Context_Fp_start(_base, _offset) ((void *) _Addresses_Add_offset( (_base), (_offset) ) ) |
| #define | _CPU_Context_Initialize_fp(_fp_area) |
| #define | _CPU_Context_Fp_start(_base, _offset) |
| #define | M68K_MOVE_A7 0x3F3C |
| #define | M68K_JMP 0x4EF9 |
| #define | CPU_MODES_INTERRUPT_LEVEL 0x00000007 /* interrupt level in mode */ |
| #define | CPU_MODES_INTERRUPT_MASK 0x00000007 /* interrupt level in mode */ |
| #define | CPU_CONTEXT_FP_SIZE sizeof( Context_Control_fp ) |
| #define | CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 1024 |
| #define | CPU_INTERRUPT_NUMBER_OF_VECTORS 256 |
| #define | CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER (CPU_INTERRUPT_NUMBER_OF_VECTORS - 1) |
| #define | CPU_PROVIDES_ISR_IS_IN_PROGRESS FALSE |
| #define | CPU_STACK_MINIMUM_SIZE M68K_CPU_STACK_MINIMUM_SIZE |
| #define | CPU_PRIORITY_MAXIMUM M68K_CPU_PRIORITY_MAXIMUM |
| #define | CPU_SIZEOF_POINTER 4 |
| #define | CPU_ALIGNMENT 4 |
| #define | CPU_HEAP_ALIGNMENT CPU_ALIGNMENT |
| #define | CPU_PARTITION_ALIGNMENT CPU_ALIGNMENT |
| #define | CPU_STACK_ALIGNMENT 0 |
| #define | _CPU_Initialize_vectors() |
| #define | _CPU_ISR_Disable(_level) m68k_disable_interrupts( _level ) |
| #define | _CPU_ISR_Enable(_level) m68k_enable_interrupts( _level ) |
| #define | _CPU_ISR_Flash(_level) m68k_flash_interrupts( _level ) |
| #define | _CPU_ISR_Set_level(_newlevel) m68k_set_interrupt_level( _newlevel ) |
| #define | _CPU_Fatal_halt(_source, _error) |
| #define | CPU_USE_GENERIC_BITFIELD_CODE FALSE |
| #define | CPU_USE_GENERIC_BITFIELD_DATA FALSE |
| #define | _CPU_Bitfield_Find_first_bit(_value, _output) |
| #define | _CPU_Priority_Mask(_bit_number) ( 0x8000 >> (_bit_number) ) |
| #define | _CPU_Priority_bits_index(_priority) (_priority) |
Typedefs | |
| typedef uint32_t | CPU_Counter_ticks |
| uint32_t | _CPU_ISR_Get_level (void) |
| Return the current interrupt disable level for this task in the format used by the interrupt level portion of the task mode. More... | |
| void | _CPU_Context_Initialize (Context_Control *the_context, void *stack_area_begin, size_t stack_area_size, uint32_t new_level, void(*entry_point)(void), bool is_fp, void *tls_area) |
| Initializes the CPU context. More... | |
| void * | _CPU_Thread_Idle_body (uintptr_t ignored) |
| This routine is the CPU dependent IDLE thread body. More... | |
| void | _CPU_Initialize (void) |
| CPU initialization. More... | |
| void | _CPU_ISR_install_raw_handler (uint32_t vector, proc_ptr new_handler, proc_ptr *old_handler) |
| This routine installs a "raw" interrupt handler directly into the processor's vector table. More... | |
| void | _CPU_ISR_install_vector (uint32_t vector, proc_ptr new_handler, proc_ptr *old_handler) |
| This routine installs an interrupt vector. More... | |
| void | _CPU_Install_interrupt_stack (void) |
| This routine installs the hardware interrupt stack pointer. More... | |
| void | _CPU_Context_switch (Context_Control *run, Context_Control *heir) |
| CPU switch context. More... | |
| void | _CPU_Context_Restart_self (Context_Control *the_context) |
| void | _CPU_Context_save_fp (Context_Control_fp **fp_context_ptr) |
| This routine saves the floating point context passed to it. More... | |
| void | _CPU_Context_restore_fp (Context_Control_fp **fp_context_ptr) |
| This routine restores the floating point context passed to it. More... | |
| void | _CPU_Exception_frame_print (const CPU_Exception_frame *frame) |
| This method prints the CPU exception frame. More... | |
| CPU_Counter_ticks | _CPU_Counter_read (void) |
| void * | _VBR |
| SCORE_EXTERN _CPU_ISR_handler_entry | _CPU_ISR_jump_table [256] |
| const unsigned char | _CPU_m68k_BFFFO_table [256] |
This include file contains information pertaining to the Motorola m68xxx processor family.
| #define _CPU_Bitfield_Find_first_bit | ( | _value, | |
| _output | |||
| #define _CPU_Context_Fp_start | ( | _base, | |
| _offset | |||
| #define _CPU_Context_Initialize_fp | ( | _fp_area | ) |
| #define _CPU_Fatal_halt | ( | _source, | |
| _error | |||
