schedulerimpl.h File Reference
Inlined Routines Associated with the Manipulation of the Scheduler. More...
#include <rtems/score/cpusetimpl.h>
#include <rtems/score/smpimpl.h>
Include dependency graph for schedulerimpl.h:
void _Scheduler_Handler_initialization (void)
 Initializes the scheduler to the policy chosen by the user. More...
RTEMS_INLINE_ROUTINE Scheduler_Context * _Scheduler_Get_context (const Scheduler_Control *scheduler)
RTEMS_INLINE_ROUTINE const Scheduler_Control * _Scheduler_Get (const Thread_Control *the_thread)
RTEMS_INLINE_ROUTINE const Scheduler_Control * _Scheduler_Get_own (const Thread_Control *the_thread)
RTEMS_INLINE_ROUTINE const Scheduler_Control * _Scheduler_Get_by_CPU_index (uint32_t cpu_index)
RTEMS_INLINE_ROUTINE const Scheduler_Control * _Scheduler_Get_by_CPU (const Per_CPU_Control *cpu)
RTEMS_INLINE_ROUTINE Scheduler_Node * _Scheduler_Thread_get_own_node (const Thread_Control *the_thread)
RTEMS_INLINE_ROUTINE void _Scheduler_Schedule (Thread_Control *the_thread)
 The preferred method to add a new scheduler is to define the jump table entries and add a case to the _Scheduler_Initialize routine. More...
RTEMS_INLINE_ROUTINE void _Scheduler_Yield (Thread_Control *the_thread)
 Scheduler yield with a particular thread. More...
RTEMS_INLINE_ROUTINE void _Scheduler_Block (Thread_Control *the_thread)
 Blocks a thread with respect to the scheduler. More...
RTEMS_INLINE_ROUTINE void _Scheduler_Unblock (Thread_Control *the_thread)
 Unblocks a thread with respect to the scheduler. More...
RTEMS_INLINE_ROUTINE void _Scheduler_Change_priority (Thread_Control *the_thread, Priority_Control new_priority, bool prepend_it)
 Propagates a priority change of a thread to the scheduler. More...
RTEMS_INLINE_ROUTINE void _Scheduler_Node_initialize (const Scheduler_Control *scheduler, Thread_Control *the_thread)
 Initializes a scheduler node. More...
RTEMS_INLINE_ROUTINE void _Scheduler_Node_destroy (const Scheduler_Control *scheduler, Thread_Control *the_thread)
 Destroys a scheduler node. More...
RTEMS_INLINE_ROUTINE void _Scheduler_Update_priority (Thread_Control *the_thread, Priority_Control new_priority)
 Updates the scheduler about a priority change of a not ready thread. More...
RTEMS_INLINE_ROUTINE int _Scheduler_Priority_compare (const Scheduler_Control *scheduler, Priority_Control p1, Priority_Control p2)
 Compares two priority values. More...
RTEMS_INLINE_ROUTINE void _Scheduler_Release_job (Thread_Control *the_thread, uint32_t length)
 Releases a job of a thread with respect to the scheduler. More...
RTEMS_INLINE_ROUTINE void _Scheduler_Tick (void)
 Scheduler method invoked at each clock tick. More...
RTEMS_INLINE_ROUTINE void _Scheduler_Start_idle (const Scheduler_Control *scheduler, Thread_Control *the_thread, Per_CPU_Control *cpu)
 Starts the idle thread for a particular processor. More...
RTEMS_INLINE_ROUTINE bool _Scheduler_Has_processor_ownership (const Scheduler_Control *scheduler, uint32_t cpu_index)
RTEMS_INLINE_ROUTINE void _Scheduler_Set (const Scheduler_Control *scheduler, Thread_Control *the_thread)
RTEMS_INLINE_ROUTINE void _Scheduler_Update_heir (Thread_Control *new_heir, bool force_dispatch)
RTEMS_INLINE_ROUTINE void _Scheduler_Generic_block (const Scheduler_Control *scheduler, Thread_Control *the_thread, void(*extract)(const Scheduler_Control *, Thread_Control *), void(*schedule)(const Scheduler_Control *, Thread_Control *, bool))
RTEMS_INLINE_ROUTINE bool _Scheduler_Is_priority_lower_than (const Scheduler_Control *scheduler, Priority_Control p1, Priority_Control p2)
 Returns true if p1 encodes a lower priority than p2 in the intuitive sense of priority.
RTEMS_INLINE_ROUTINE bool _Scheduler_Is_priority_higher_than (const Scheduler_Control *scheduler, Priority_Control p1, Priority_Control p2)
 Returns true if p1 encodes a higher priority than p2 in the intuitive sense of priority.
RTEMS_INLINE_ROUTINE uint32_t _Scheduler_Get_processor_count (const Scheduler_Control *scheduler)
RTEMS_INLINE_ROUTINE Objects_Id _Scheduler_Build_id (uint32_t scheduler_index)
RTEMS_INLINE_ROUTINE uint32_t _Scheduler_Get_index_by_id (Objects_Id id)
RTEMS_INLINE_ROUTINE bool _Scheduler_Get_by_id (Objects_Id id, const Scheduler_Control **scheduler_p)
RTEMS_INLINE_ROUTINE bool _Scheduler_Is_id_valid (Objects_Id id)
RTEMS_INLINE_ROUTINE uint32_t _Scheduler_Get_index (const Scheduler_Control *scheduler)
RTEMS_INLINE_ROUTINE Scheduler_Node * _Scheduler_Thread_get_node (const Thread_Control *the_thread)
RTEMS_INLINE_ROUTINE void _Scheduler_Node_do_initialize (Scheduler_Node *node, Thread_Control *the_thread)
RTEMS_INLINE_ROUTINE void _Scheduler_Acquire (Thread_Control *the_thread, ISR_lock_Context *lock_context)
 Acquires the scheduler instance of the thread. More...
RTEMS_INLINE_ROUTINE void _Scheduler_Release (Thread_Control *the_thread, ISR_lock_Context *lock_context)
 Releases the scheduler instance of the thread. More...
This inline file contains all of the inlined routines associated with the manipulation of the scheduler.
