Typedefs | Functions
rtl-unwind-dw2.h File Reference
RTEMS Run-Time Linker Unwind DWARF Support. More...
#include "rtl-elf.h"
Include dependency graph for rtl-unwind-dw2.h:
typedef long rtems_rtl_elf_unwind_dw2_sleb128
typedef unsigned long rtems_rtl_elf_unwind_dw2_uleb128
bool rtems_rtl_elf_unwind_dw2_parse (const rtems_rtl_obj_t *obj, const char *name, uint32_t flags)
 Architecture specific handler to check if a section contains exception handler data. More...
bool rtems_rtl_elf_unwind_dw2_register (const rtems_rtl_obj_t *obj)
 Architecture specific handler to add an object file's unwind information to the base image. More...
bool rtems_rtl_elf_unwind_dw2_deregister (const rtems_rtl_obj_t *obj)
 Architecture specific handler to remove an object file's unwind information from the base image. More...
const uint8_t * rtems_rtl_elf_unwind_dw2_read_uleb128 (const uint8_t *data, rtems_rtl_elf_unwind_dw2_uleb128 *val)
 Read signed and unsigned LEB128 values.
const uint8_t * rtems_rtl_elf_unwind_dw2_read_sleb128 (const uint8_t *data, rtems_rtl_elf_unwind_dw2_sleb128 *val)
bool rtems_rtl_elf_unwind_dw2_relocate (const Elf_Addr *where, Elf_Word value, Elf_Word mask)
◆ rtems_rtl_elf_unwind_dw2_deregister()
bool rtems_rtl_elf_unwind_dw2_deregister ( const rtems_rtl_obj_t *  obj)
Parameters
objThe object file.
Return values
trueThe unwind information has been deregistered.
falseThe unwind information could not be deregistered.
References rtems_rtl_obj_sect_s::base, rtems_rtl_obj_find_section(), and rtems_rtl_obj_sect_s::size.
Referenced by rtems_rtl_elf_unwind_deregister().
◆ rtems_rtl_elf_unwind_dw2_parse()
bool rtems_rtl_elf_unwind_dw2_parse ( const rtems_rtl_obj_t *  obj,
const char *  name,
uint32_t  flags
Parameters
objThe object file.
nameThe section's name.
uint32flags The object file's flags.
Return values
trueThe section contains unwind information.
falseThe section does not contain unwind information.
References RTEMS_RTL_OBJ_SECT_CONST.
Referenced by rtems_rtl_elf_unwind_parse().
◆ rtems_rtl_elf_unwind_dw2_register()
bool rtems_rtl_elf_unwind_dw2_register ( const rtems_rtl_obj_t *  obj)
Parameters
objThe object file.
Return values
trueThe unwind information has been registered.
falseThe unwind information could not be registered.
Referenced by rtems_rtl_elf_unwind_register().
