Set of Utility Functions to Support RTEMS RFS on RTEMS. More...
#include <sys/types.h>
#include <sys/stat.h>
#include "rtems-rfs-rtems.h"
Include dependency graph for rtems-rfs-rtems-utils.c:
bool rtems_rfs_rtems_set_handlers (rtems_filesystem_location_info_t *loc, rtems_rfs_inode_handle *inode)
 Set the handlers in the path location based on the mode of the inode. More...
uint16_t rtems_rfs_rtems_imode (mode_t mode)
 Convert the system mode flags to inode mode flags. More...
mode_t rtems_rfs_rtems_mode (int imode)
 Convert the inode mode flags to system mode flags. More...
◆ rtems_rfs_rtems_imode()
uint16_t rtems_rfs_rtems_imode ( mode_t  mode)
Parameters
[in]modeis the system mode flags.
Returns
uint16_t The inode mode flags.
◆ rtems_rfs_rtems_mode()
mode_t rtems_rfs_rtems_mode ( int  imode)
Parameters
[in]imodeis the inode mode flags
Returns
mode_t The system mode flags.
References rtems_rfs_rtems_error.
◆ rtems_rfs_rtems_set_handlers()
bool rtems_rfs_rtems_set_handlers ( rtems_filesystem_location_info_t *  pathloc,
rtems_rfs_inode_handle *  inode
Parameters
[in]locis a pointer to the path location to set the handlers in.
[in]inodeis the inode handle to check the mode of for the type of handlers.
Return values
trueThe handlers have been set.
falseThere are no handlers for the mode.
