RTEMS File System Mutex. More...
#include <rtems/rfs/rtems-rfs-mutex.h>
Include dependency graph for rtems-rfs-mutex.c:
int rtems_rfs_mutex_create (rtems_rfs_mutex *mutex)
 Create the mutex. More...
int rtems_rfs_mutex_destroy (rtems_rfs_mutex *mutex)
 Destroy the mutex. More...
◆ rtems_rfs_mutex_create()
int rtems_rfs_mutex_create ( rtems_rfs_mutex *  mutex)
Create the mutex.
Parameters
[in]mutexis pointer to the mutex handle returned to the caller.
Return values
0Successful operation.
EIOAn error occurred.
References rtems_build_name, rtems_rfs_trace(), rtems_semaphore_create(), and RTEMS_SUCCESSFUL.
◆ rtems_rfs_mutex_destroy()
int rtems_rfs_mutex_destroy ( rtems_rfs_mutex *  mutex)
Destroy the mutex.
Parameters
[in]mutexReference to the mutex handle returned to the caller.
Return values
References rtems_rfs_trace(), rtems_semaphore_delete(), and RTEMS_SUCCESSFUL.
Referenced by rtems_rfs_rtems_shutdown().
